Adding units to an attribute
Units within OpenRemote are for UI purposes; for something like temperature it is just stored as a number, there is no special treatment for storage, but if you want to show units in the UI then the following explains how to do it:
You can create a custom attribute on an asset and then add a Units Configuration Item, which allows you to define units using a list of strings which loosely follow the HTML internationalisation spec.
You can find currently supported unit strings in:
For example to add celsius units to an attribute:
