hi,
I have a AtagOne thermostaat connected on my wifi network.
On internet i found on Github the atag-one-api project.
I downloaded the file atag-one.jar in my controller/bin directory.
When i open a terminal in the controller/bin directory I can run the following command:
$ java -jar atag-one.jar --skip-auth-request 192.168.xxx.xxx
This command give a responce with all the thermostate settings.
The next step is to run this command an get the response in a sensor.
I made a command with the shell execution protocol.
How do i have to configurate this with the a (directory) path in it?
Is this the best solution to get the info into a sensor?
Kind regards
Arjen
