Hi!
What do you mean with “customize the Dashboard” ?
There are plenty of widgets available in the Manager by default, that should fill your needs.
Or are you referring to building custom widgets in code, specifically for your use case?
There are a lot of forum posts on this topic, like this one. It’s a bit tricky using the custom projects template, but I’ve explained it in the official documentation, that can be found here:
