Question
i’m trying to build and run the code source from an ide
os : Ubuntu 20.04 lts
ide : iintellij
Java 17 JDK
GIT
NodeJS]
yarn
Docker Machine is Deprecated so i have to use Docker image with tooling
this error appears
docker run --rm -v pwd
:/or registry.gitlab.com/openremote/openremote:master git status
docker: Got permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Post “http://%2Fvar%2Frun%2Fdocker.sock/v1.24/containers/create”: dial unix /var/run/docker.sock: connect: permission denied.
See ‘docker run --help’.
so could any one please provide the full steps to build and run the code
Out of the box docker requires sudo to run on linux. Please google it out because there is a way to configure it to run without sudo.
