Hello all,
I’m having trouble trying to create Group Assets. No matter its (intended) place in the hierarchy, the command always ends with the “Failed to create asset” dialog.
Any hints?
thanks,
cl.
Hello all,
Any hints?
thanks,
cl.
Hi Claudio, we are aware of it. It’s pending a structural solution.
However, there is a workaround:
And just to be clear, a GroupAsset is a special asset type that only accepts assets with an asset type of the set childAssetType as its children. So trying to add an asset with a different asset type will result in an error (which should be a bit more descriptive…).
As Pierre said, we are working on additional functionality for this GroupAsset asset type.
FYI, you can use any asset to group other assets.
Hi Pierre, thanks for your reply.
I’m not sure I’m understanding your instructions, childAssetType and other attribs always appears grayed out and are not editable, this is how I see them:
thanks again,
cl.
Hi Don, thanks for your comments.
Yes, this is how I’m doing it right now. It’s ok, will wait for news…
thanks,
cl.
Hi Claudio, I clarified the instruction (see above)
