Apply a different colour to a label’s value returned depending on the value within a custom sensor
Ie.If it is 0 display OFFLINE in red and if its a 1 display ONLINE in white
I have a camera view screen (see attached) and from the buttons on the left I want to be able to select/switch the camera feed to be display in the right box
Can RULES help accomplish these and any code snippets or help appreciated
thanks
any idea where and how to make this connection between the sensor state and the image
For a sensor I only see a place to add text or is the answer here one of those in-memory commands
You can do this for a custom sensor type. Define custom states items for it, for each image one. Then, when you place this sensor on a screen you can link an image to each custom state.
What designer are you using? In the designer.openremote.com I can click on the Sensor State field and then I get the pop-up window where I can select an image. On yours picture there is text input screen. Maybe you can put there just image name which you’ve uploaded to the designer?
