EnOcean
Has anyone had any trouble using EnOcean with the latest OR version?
Everything i get in the log below. Any ideas?
I’m using the EnOceanPi i’ve mapped the serial port to ttyS80, this worked in previous versions.
INFO 2016-07-17 09:18:00,202 (EnOcean): Started reader thread for port [COM port: /dev/ttyS80, Protocol: ESP3, Communication Layer: RXTX]
INFO 2016-07-17 09:18:00,327 (EnOcean): Received EnOcean gateway base ID : 0xFFAA6700
WARN 2016-07-17 09:18:00,330 (EnOcean): Unknown EnOcean property ‘’.
WARN 2016-07-17 09:18:00,331 (EnOcean): Unknown EnOcean property ‘’.
INFO 2016-07-17 09:18:00,930 (EnOcean): Created EnOcean Command (ID = ‘0x018187A7’, EEP (Type = ‘A5-02-05’, Data = ‘0x00 0x00 0x00 0x00’)).
Thanks in advance.
Some more info in the log, not sure why it is shutting down.
DEBUG 2016-07-17 12:59:59,833 (EnOcean): Adding shutdown hook to manage unclosed EnOcean connections in case of controller exit.
DEBUG 2016-07-17 13:00:00,229 (EnOcean): Try to read EnOcean module base ID (retry count = 1)
INFO 2016-07-17 13:00:00,251 (EnOcean): Started reader thread for port [COM port: /dev/ttyS80, Protocol: ESP3, Communication Layer: RXTX]
TRACE 2016-07-17 13:00:00,321 (EnOcean): Received serial data from [COM port: /dev/ttyS80, Protocol: ESP3, Communication Layer: RXTX] : 0x55 0x00 0x05 0x01 0x02 0xDB 0x00 0xFF
TRACE 2016-07-17 13:00:00,325 (EnOcean): Received serial data from [COM port: /dev/ttyS80, Protocol: ESP3, Communication Layer: RXTX] : 0xAA 0x67 0x00 0x0A 0xBF
INFO 2016-07-17 13:00:00,353 (EnOcean): Received EnOcean gateway base ID : 0xFFAA6700
WARN 2016-07-17 13:00:00,355 (EnOcean): Unknown EnOcean property ‘’.
INFO 2016-07-17 13:00:00,935 (EnOcean): Created EnOcean Command (ID = ‘0x018187A7’, EEP (Type = ‘A5-02-05’, Data = ‘0x00 0x00 0x00 0x00’)).
TRACE 2016-07-17 13:01:35,114 (EnOcean): Received serial data from [COM port: /dev/ttyS80, Protocol: ESP3, Communication Layer: RXTX] : 0x55 0x00 0x0A 0x07 0x01 0xEB 0xA5 0x00
TRACE 2016-07-17 13:01:35,119 (EnOcean): Received serial data from [COM port: /dev/ttyS80, Protocol: ESP3, Communication Layer: RXTX] : 0x00 0x4D 0x08 0x01 0x81 0x87 0xA7 0x00 0x01 0xFF 0xFF 0xFF 0xFF 0x29 0x00 0x7F
DEBUG 2016-07-17 13:01:35,126 (EnOcean): Received radio telegram : [RADIO: RORG=4BS, sender ID=0x018187A7, payload=0x00 0x00 0x4D 0x08, status=0x00]
TRACE 2016-07-17 13:15:39,662 (EnOcean): Received serial data from [COM port: /dev/ttyS80, Protocol: ESP3, Communication Layer: RXTX] : 0x55
TRACE 2016-07-17 13:15:39,667 (EnOcean): Received serial data from [COM port: /dev/ttyS80, Protocol: ESP3, Communication Layer: RXTX] : 0x00 0x0A 0x07 0x01 0xEB 0xA5 0x00 0x00 0x4D 0x08 0x01 0x81 0x87 0xA7
TRACE 2016-07-17 13:15:39,670 (EnOcean): Received serial data from [COM port: /dev/ttyS80, Protocol: ESP3, Communication Layer: RXTX] : 0x00 0x01 0xFF 0xFF 0xFF 0xFF 0x29 0x00 0x7F
DEBUG 2016-07-17 13:15:39,672 (EnOcean): Received radio telegram : [RADIO: RORG=4BS, sender ID=0x018187A7, payload=0x00 0x00 0x4D 0x08, status=0x00]
DEBUG 2016-07-17 13:16:34,126 (EnOcean): Executing JVM shutdown hook to close EnOcean connections…
TRACE 2016-07-17 13:16:34,271 (EnOcean): Received serial data from [COM port: /dev/ttyS80, Protocol: ESP3, Communication Layer: RXTX] :
INFO 2016-07-17 13:16:34,272 (EnOcean): Shutting down reader thread for port [COM port: /dev/ttyS80, Protocol: ESP3, Communication Layer: RXTX]
