Is there a way to migrate all the information about sensors and devices from my current OR server to a fresh installation (same SW version)?
I believe I might have messed some OR files… and I want to do a clean install, but I would like to avoid having to add ALL the devices again to the z-wave controller.
What do you mean by OR server? If this is the same as OR controller the simply synchronising the new install with designer will do the trick. If you mean a new designer account, then you can export from the old one and import it to the new one.
Mi Michal
Just a follow up question… will all the xml files in the ~/openremote/webapps/controller/zwave/ folder be imported from the z-stick, or do I have to copy them manually?
//David.
