Hi! Setting the config environment variable incorrectly does not fail the startup process on my system.
If the config cannot be found, it will still serve the app. So you can take care of this later in case it fails in runtime.
However I see modelWatch giving a status of 1, which could have caused the issue.
Can you provide the logs of this command?
First of all thank you for your reply, I already did that but the error message is very undescriptive… Here: Build Scan™ | Gradle Cloud Services
you can see the output of ./gradlew modelWatch --scan so you can get a picture for yourself!
Thanks in advance!
--- Fails ---
PS E:\RemoteMeter\Software\RemotePlatform\openremote\ui\app\manager> npm run serve
Running gradlew modelBuild task in E:\RemoteMeter\Software\RemotePlatform ...
gradlew modelWatch finished! Status = 1
I have zero clue why it occurs, since I have never used the custom project template myself.
In the main openremote repo it is working fine, so this might be specific to the template.
But it seems to be an issue with the directory used by the scripts. @MarkusAtCoduct might be experiencing the same after I just read the logs from the 1st post again.
