Hi everyone,
Would anyone have experience getting a volume slider working with a Marantz 7005 and OpenRemote?
When I use Marantz protocol to set a volume value command and try to adjust the slider in the iOS client, this comes in dev.log and the client crashes:
2017-12-28 15:15:25,087 ERROR [HTTP-Thread-4]: Error executing command ‘/620/44’ : Invalid volume parameter value (${param})
org.openremote.controller.exception.NoSuchCommandException: Invalid volume parameter value (${param})
In the error above, the value 44 would seem to indicate that the slider value is properly read? At least it is the value I was adjusting the slider to.
If I use normal int values like 25, 35 etc. in the volume value parameter slot in Designer, these work just fine.
Cheers,
Jani
