I understand where the need for this might emerge, especially for users that may not be that well-versed with software development. But, given that OpenRemote is an open-source project, you are more than welcome to create a new pull request!
I was talking about using parsers within OpenRemote code, within the custom MQTT handler.
Yeah, I wrote that MQTT handler, it’s still a work in progress
. It is a good place to start if I may say so myself, but also the MQTT Handler abstract class, that contains documentation for (I think) all of the methods you may want to implement. There’s also the forum thread about an MQTT sparkplug integration, where I go a bit more in-depth about how to create an MQTT handler.
I would also like to mention that I do not want to make a custom MQTT handler appear to be a one-stop-shop for all OpenRemote users with an MQTT device. I think that the pros for it outweigh its cons, if we remove the concept of required knowledge or time requirements. I just wanted to show this functionality as a very useful tool, which enables me to create integrations for devices at a level that has never been seen before.
Here you mention how power and bandwidth limitations are also quite significant for your use case. To me, this sounds like this could lead to real issues pertaining to cost. It also sounds like an implementation like this could be mission-critical for a project you may be taking on. This is one of those use-cases where I do believe that a custom MQTT handler would just make your life a lot easier. If people are thinking of network overhead for IoT devices creating unnessessary cost, then I do consider it to be an issue that deserves its own MQTT handler as a solution.
In total, I do understand that need of some users for writeattributevalues, but I also need to highlight the importance of custom MQTT handlers for use-cases like these. In any case, opening a pull request is free, and it would improve OpenRemote as a whole!
