Thanks Stuart
I’ll give that a go.
I searched the openremote community re the second one and the same question was asked but unfortunately the site seems to be offline and i can see the response. Hopefully the site will come back soon.
Thanks for taking the time to respond.
Regards
Frank
Hi Frank,
Your question about getting buttons to change the content of webview elements got my imagination fired up.
The attached ZIP contains a working solution.
In short, you’ll need to create an “In-Memory” command that places the desired URL into a register.
Then a simple status In-Memory command to recall the string.
A simple custom sensor to display the string.
Then just link the webview to that sensor.
I’m not sure if the webview needs a default URL to start working, but you can try that for yourself.
Good luck,
Stuart
openremote-DynamicURL-Webview.zip (207 KB)
