Hi Everyone, this is my first post and it concerns the OR synchronisation. I’m currently running Controller V2.6.1 and using Designer V2.5.0.
When I first upgraded to Controller 2.6.0 (a few months ago), I had an issue synchronising whereby if I did an online synch, the connection between the Controller and KNX stopped. I was not able to establish what the issue was but I was able to download the .zip file from the online Designer and perform an offline synchronisation which worked (I was able to update the GUI in Designer and save OK and this allowed me to download the .zip file to perform the offline synchronising).
When it became available, I upgraded to Controller V.2.6.1 and further testing revealed the synchronisation problem remained, but again, I was able to get by with offline synchronising.
Yesterday (19-Aug) I was updating the GUI in Designer and this was working (by performing offline Synchronising) but then around 10pm UK time, I was getting a blank screen when I tried to access the online Designer (internet connection was working for any other sites). I then tried to access the Designer this morning and it was up again and so I updated the GUI and saved accordingly (which works fine), but I discovered that the synchronisation issue has now extended to offline synchronising (although with the offline synchronisation, the communication between the Controller and KNX still works, it’s just that the changes saved in the online Designer do not exist in the updated Controller) . The result is that while I can update the GUI in Designer and save, I am unable to transfer these changes to the Controller on my server.
Has anyone experienced such issues?
