Postgress container upgrade from 14.x to 15.x failed
Team,
i have used this service for 1 year , and I just tried updating to the latest postgres image 15.x from 14.x and the container now fails to start with error message:
Postgres major version is newer than the existing DB, performing auto upgrade...
Looks like the server did not previously shutdown properly which will prevent pg_upgrade from working
try stopping the whole stack, bringing only the postgresql container up and then stopping it again
Hey,
OK so you tried to upgrade to the latest postgres and the upgrade failed; this is likely because you didn’t stop the existing stack (there is a bug in our 14.x postgres docker image which means it doesn’t respond to SIGINT message and ends up being killed by docker so the DB is left in a state that means auto upgrade will not run).
As the error message suggests: -
You just need to start the postgres container using the old image and then stop the stack, something like:
POSTGRESQL_VERSION=14.6.0.3 docker compose -p openremote up postgresql
Once it is running you can exit Ctrl-C and the DB should be stopped in a healthy state; you can then try bringing up the stack with the newer postgres image.
POSTGRESQL’s health is ok but the problem in keycloak , its restarted .
So you managed to upgrade the postgresql container successfully now?
If so please share error logs from keycloak.
