Problem defining a variable from a sensor
Hello all,
I’m having a problem defining a variable from a sensor state.
The sensor is a HTTP GET command and produces a value, for example 16.5. I’m not sure is this is a “char” string.
This is the command I’m using:
CustomState(source == “Dummy”, setpointinit : value);
In boot.log I see the following error:
Rule Compilation error source cannot be resolved to a variable
Syntax error on token “:”, :: expected
Can someone help?
Thanks in advance
Cheers,
Rene
Seems like there is ; after CustomState(). Remove it. In case of more errors send the complete code.
Hello Michal,
Removing the ; did not solve my problem. I guess I’m going about it the wrong way.
I’m not a Java programmer :slight_smile:
The thing I’m trying to do is relatively simpel:
Assign an initial value to an in-memory sensor using the value of another sensor.
I’ve been looking at a lot of examples but I can’t work it out…
Could you give me some pointers?
Thanks.
Regards,
Rene
Are you getting the same syntax error? Please send the complete rule which isn't working as it should. Also, please try to explain the complete scenario you want to do.
As a basis I used the demo example. The functionality is a display of a temperature with a “+” an “-” button for controlling a thermostat.
This part I got working. My problem is setting the initial value of the display. For this I want to use the acual setting of the thermostat.
The sensor is working but I can’t get this value into a variable.
The error is:
setpointinit cannot be resolved
Code of the rule:
rule “-PSB: Init”
salience 10
then
execute.command(“kachel-setpoint-inc”,“OFF”);
execute.command(“kachel-setpoint-dec”,“OFF”);
end
At least you’ve missed the LHS of the rule. It should look something like:
rule “init”
when
then
// and here you need to set the initial value of your thermostat
execute.command(“your thermostat setpoint command”, setpointinit.toString() );
end
Ok, that gets the value in the variable but it gets updated every time the value of “Dummy” changes…
Then you need to init it only when the value is not initialized yet, like this one
rule "init"
when
  CustomState(source == "Dummy", setpointinit : value)
  Event(source=="your thermostat set point sensor in-memory var", value=="")
then
  execute.command("your thermostat setpoint command", setpointinit.toString() );
end
Uninitialized var can be either empty stiring "" or "status". You can have two rules to cover both.
Hi Michal,
Finally I’ve got it working :slight_smile:
I think the main problem was that the defining of the variable is done in the “when” part. That wasn’t logical to me…
Thanks for the assist.
Cheers,
Rene
Glad to hear this! It would be nice if you can post the final rules which are working for you. This way, the others with similar problem can see how it should be done.
And here’s the complete code of the rules for my thermostat:
import java.util.;
import java.util.Date;
import java.text.SimpleDateFormat;
import java.io.
import org.openremote.controller.model.event.*;
import org.openremote.controller.utils.Logger;
import org.openremote.controller.Constants;
function void log(String msg)
Logger.getLogger(Constants.RUNTIME_EVENTPROCESSOR_LOG_CATEGORY + “.drools”).debug(msg);
declare Event
@role(event)
end
rule “init”
salience 10
when
CustomState(source == “kachel-setpoint-status”, setpointinit : value)
Event(source == “kachel-setpoint”, value == “”)
then
execute.command(“kachel-setpoint”,setpointinit);
end
function Double _GetTemp(Object o){
String s = o.toString();
try{
if(s.length()>1){
return(Double.parseDouble(s.substring(0, s.length()-1)));
}else{
return(0.0);
} catch (NumberFormatException e) {
return(0.0);
function String _ShiftTemp(Object o, double sh){
try{
Double t = Double.parseDouble(s.substring(0,s.length()-1)) + sh;
return(String.format("%.1f\u00B0",t));
return(“0.0\u00B0”);
function String _ShiftTemp_noformat(Object o, double sh){
try{
String rs = t.toString();
return(rs.substring(0,4));
rule “kachel-setpoint inc”
timer(int:10ms)
when
Event(source == “kachel-setpoint”, $v: value, eval(_GetTemp(value) < 23))
Event(source == “kachel-setpoint-inc” , value == “ON”)
then
execute.command(“kachel-setpoint-inc”,“off”);
execute.command(“kachel-setpoint”, _ShiftTemp($v.toString(), 0.5));
execute.command(“kachel-setpoint-set”, _ShiftTemp_noformat($v.toString(), 0.5));
end
rule “kachel-setpoint dec”
timer(int:10ms)
when
Event(source == “kachel-setpoint”, $v: value, eval(_GetTemp(value) > 15))
Event(source == “kachel-setpoint-dec” , value == “ON”)
then
execute.command(“kachel-setpoint-dec”,“off”);
execute.command(“kachel-setpoint”, _ShiftTemp($v.toString(), -0.5));
execute.command(“kachel-setpoint-set”, _ShiftTemp_noformat($v.toString(), -0.5));
end
rule “kachel-setpoint INC/dec” // needed when change on the boundary
salience -10
timer(int:300ms)
when
then
end
rule “kachel-setpoint inc/DEC” // needed when change on the boundary
salience -10
timer(int:300ms)
when
then
end
