Problems with the Samsung remote protocol
Hi all,
I’m having problems getting the Samsung protocol working.
I followed the instructions on https://github.com/openremote/Documentation/wiki/Samsung-Smart-TV.
There is an inconsistancy in this page. It says:
  • In the moment you cannot do this via the designer which means you have to edit the file “config.properties” manually.
    and than at the bottom:
  • The IP address of the Samsung TV is not configured via the “config.properties” file anymore but directly in the Designer.
Anyway, I put the samsungtv.jar in webapps/controller/WEB-INF/lib and added the IP address to the controller config in the designer.
No messages in boot or dev… and it doesn’t work.
The same configuration works fine in my 2.1 version. There is a difference however.
In the 2.1 version there are 4 files in ./webapps/controller/WEB-INF/classes/org/openremote/controller/protocol/samsungtv:
Key.class
SamsungTVCommand.class
SamsungTVRemoteCommandBuilder.class
SamsungTVSession.class
In the 2.6b3 there is only one:
Also there is no “dummy” samsung.jar file in webapps/controller/WEB-INF/lib
It seems there is something missing in the new controller configuration.
Could somebody have a look at this?
Thanks in advance!
Regards,
Rene Selles
