Hello
is it possible with the rules to redirect to a screen ?
example:
rule “etat_detecteur_porte_on”
when
Event( source == "VCODE", value == "0123" )
then
displayed( “screen1”);
end
thank you
Hello
example:
when
then
end
thank you
Not quite sure what do you want to do? If you simply want to display something which was generated in a rule on your user interface then you can use a Label linked with the in memory command and set this command in the rule, like
execute.command(“in memory protocol command”, “text to show”);
your rule is interesting but that’s not what I’m looking for.
I would like after typing my code on the clavier screen to be redirected to the acceuil screen.
Thank you very much.
reference screen accueil in panel.xml :
reference screen clavier in panel.xml
