ive made a command which sends parameters(from rules) to my thermostat, it will send back a json string, ive attached a sensor to it to read it.
it has worked before but now my sensors.log says that there is no polling interval given (which is also not needed) any known issued or is it because of an designer update?
error logfile:
ERROR 2016-08-04 09:32:45,060 : There was an implementation error in the event listener associated with sensor ‘3M50_Online_check’. The listener implementation may not have started correctly : Could not set sensor because no polling interval was given
java.lang.RuntimeException: Could not set sensor because no polling interval was given
at org.openremote.controller.protocol.http.HttpGetCommand.setSensor(HttpGetCommand.java:174)
at org.openremote.controller.model.sensor.Sensor.start(Sensor.java:387)
at org.openremote.controller.deployer.Version20ModelBuilder.buildSensorModel(Version20ModelBuilder.java:673)
at org.openremote.controller.deployer.Version20ModelBuilder.build(Version20ModelBuilder.java:557)
at org.openremote.controller.deployer.AbstractModelBuilder.buildModel(AbstractModelBuilder.java:154)
at org.openremote.controller.service.Deployer.startup(Deployer.java:872)
at org.openremote.controller.service.Deployer.startController(Deployer.java:350)
at org.openremote.controller.spring.SpringContext.initializeController(SpringContext.java:109)
at org.openremote.controller.service.ServiceContext.init(ServiceContext.java:427)
at org.openremote.controller.bootstrap.Startup.loadServiceContext(Startup.java:88)
at org.openremote.controller.bootstrap.servlet.ServletStartup.initializeServiceContext(ServletStartup.java:195)
at org.openremote.controller.bootstrap.servlet.ServletStartup.contextInitialized(ServletStartup.java:109)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3843)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4342)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:791)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:771)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:525)
at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:926)
at org.apache.catalina.startup.HostConfig.deployDirectories(HostConfig.java:889)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:492)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1149)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:311)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:117)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1053)
at org.apache.catalina.core.StandardHost.start(StandardHost.java:719)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1045)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
at org.apache.catalina.core.StandardService.start(StandardService.java:516)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:710)
at org.apache.catalina.startup.Catalina.start(Catalina.java:578)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:288)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:413)
ive always used the staging designer https://composer.openremote.org/staging/Modeler.jsp
username: robke
