Is it possible to install both versions next to each other on a raspi?
I want to set a a new configuration, but in that time, still use my old one.
As i understand, the new one has the same setup as the old one! Correct?
Already thanks.
Already thanks.
Yes, you must just make sure that all used tomcat ports are different if you’re running 2 versions at the same time.
