I have a volume slider which can be set from 0 - 20
The value should be used in a command like: MV${param}
Now the problem: the value ${param} should represent is always 2-digits ( 00 , 01 , 02 etc.)
I need the first values to have a leading zero.
michal
#2
You will have to use rules for this. Then you can format a string sent any way you like.
I tried this:
import java.util.*;
rule “CEOL Volume einstellen” when
$evt:Event( source == “Volume Slider”, $val : value)
then
String valStr = $val.toString();
if (valStr != null ) {
String twodigits = String.format("%02d", valStr);
execute.command( "Volume einstellen TCPIP", twodigits);
end
but it does not work…
