Hi.
I tried this way:
The image for Docker on the Synology I downloaded from here: https://hub.docker.com/r/sybdata/homebridge/
My configuration files for install and config for homebridge-openremote (for Fibaro Dimmer and the Two-channel relay) in the attachment.
In log:
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
stdout
13:53:32
npm info it worked if it ends with ok
stdout
13:53:32
npm info using npm@4.2.0
stdout
13:53:32
npm info using node@v7.10.1
stdout
13:53:32
npm info ok
stdout
13:53:32
[37m[7/28/2017, 1:53:32 PM][39m Loaded plugin: homebridge-openremote
stdout
13:53:32
[37m[7/28/2017, 1:53:32 PM][39m Registering accessory 'homebridge-openremote.openremote'
stdout
13:53:32
[37m[7/28/2017, 1:53:32 PM][39m ---
stdout
13:53:32
[37m[7/28/2017, 1:53:32 PM][39m Loaded plugin: homebridge-server
stdout
13:53:32
[37m[7/28/2017, 1:53:32 PM][39m Registering platform 'homebridge-server.Server'
stdout
13:53:32
stdout
13:53:32
[37m[7/28/2017, 1:53:32 PM][39m Loaded config.json with 3 accessories and 0 platforms.
stdout
13:53:32
stdout
13:53:32
[37m[7/28/2017, 1:53:32 PM][39m Loading 3 accessories...
stdout
13:53:32
[37m[7/28/2017, 1:53:32 PM][39m [36m[Dimmer][39m Initializing openremote accessory...
stdout
13:53:32
[37m[7/28/2017, 1:53:32 PM][39m [36m[Switch 1][39m Initializing openremote accessory...
stdout
13:53:32
[37m[7/28/2017, 1:53:32 PM][39m [36m[Switch 2][39m Initializing openremote accessory...
stdout
13:53:32
[37m[7/28/2017, 1:53:32 PM][39m [36m[Dimmer][39m Switch received status http://192.168.1.3:8688/controller/rest/status/403148 state is currently 0
stdout
13:53:32
[37m[7/28/2017, 1:53:32 PM][39m [36m[Dimmer][39m Setting power state to off
stdout
13:53:32
[37m[7/28/2017, 1:53:32 PM][39m [36m[Switch 1][39m Switch received status http://192.168.1.3:8688/controller/rest/status/403150 state is currently 0
stdout
13:53:32
[37m[7/28/2017, 1:53:32 PM][39m [36m[Switch 1][39m Setting power state to off
stdout
13:53:32
[37m[7/28/2017, 1:53:32 PM][39m [36m[Switch 2][39m Switch received status http://192.168.1.3:8688/controller/rest/status/403151 state is currently 0
stdout
13:53:32
[37m[7/28/2017, 1:53:32 PM][39m [36m[Switch 2][39m Setting power state to off
stdout
13:53:33
[37m[7/28/2017, 1:53:33 PM][39m [36m[Switch 1][39m HTTP set power function succeeded!
stdout
13:53:33
[37m[7/28/2017, 1:53:33 PM][39m [36m[Switch 2][39m HTTP set power function succeeded!
stdout
13:53:33
[37m[7/28/2017, 1:53:33 PM][39m [36m[Dimmer][39m HTTP set power function succeeded!
stdout
13:53:33
Scan this code with your HomeKit App on your iOS device to pair with Homebridge:
stdout
13:53:33
[30m[47m [49m[39m
stdout
13:53:33
[30m[47m ┌────────────┐ [49m[39m
stdout
13:53:33
[30m[47m │ 031-45-154 │ [49m[39m
stdout
13:53:33
[30m[47m └────────────┘ [49m[39m
stdout
13:53:33
[30m[47m [49m[39m
stdout
13:53:33
[37m[7/28/2017, 1:53:33 PM][39m Homebridge is running on port 51826.
stdout
13:54:43
[37m[7/28/2017, 1:54:43 PM][39m [36m[Switch 1][39m Switch received status http://192.168.1.3:8688/controller/rest/status/403150 state is currently 0
stdout
13:54:43
[37m[7/28/2017, 1:54:43 PM][39m [36m[Switch 1][39m Setting power state to off
stdout
13:54:43
[37m[7/28/2017, 1:54:43 PM][39m [36m[Switch 1][39m HTTP set power function succeeded!
stdout
13:54:03
[37m[7/28/2017, 1:55:03 PM][39m [36m[Switch 1][39m Switch received status http://192.168.1.3:8688/controller/rest/status/403150 state is currently 1
stdout
13:54:03
[37m[7/28/2017, 1:55:03 PM][39m [36m[Switch 1][39m Setting power state to on
stdout
13:54:03
[37m[7/28/2017, 1:55:03 PM][39m [36m[Switch 1][39m HTTP set power function succeeded!
stdout
13:54:29
[37m[7/28/2017, 1:55:29 PM][39m [36m[Switch 1][39m Switch received status http://192.168.1.3:8688/controller/rest/status/403150 state is currently 0
stdout
13:54:29
[37m[7/28/2017, 1:55:29 PM][39m [36m[Switch 1][39m Setting power state to off
stdout
13:54:29
[37m[7/28/2017, 1:55:29 PM][39m [36m[Switch 1][39m HTTP set power function succeeded!
[.env|attachment](upload://9RudXGCPAOYAg7BRe5bPdyFKfQq) (393 Bytes)
[config.json|attachment](upload://1ynl8JPCA5ZVxGSF0Hx9CQZneUL.json) (1.42 KB)
[install.sh|attachment](upload://3bCTjMMfOVJE8Dt8aI8qWEJGLcG.sh) (217 Bytes)
[package.json|attachment](upload://c8fSREJFgpvsqG2CcftfnEOCOi3.json) (852 Bytes)
