I cannot seem to have a sensor reflect that status of my GE Z-Wave light switch when I operate the switch manually. I do see the following in the zwave.log:
Switch manually turned on:
DEBUG 2016-07-02 16:39:56,620 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-07-02 16:39:56,624 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x10, 0x00, 0x49, 0x84, 0x02, 0x0A, 0x04, 0x10, 0x01, 0x25, 0x27, 0x73, 0x70, 0x86, 0x72, 0x77, 0xBD]
DEBUG 2016-07-02 16:39:56,630 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x10, 0x00, 0x49, 0x84, 0x02, 0x0A, 0x04, 0x10, 0x01, 0x25, 0x27, 0x73, 0x70, 0x86, 0x72, 0x77, 0xBD] has been received.
DEBUG 2016-07-02 16:39:56,635 (Z-Wave): RX_Session_Layer : ‘Application Controller Update’ frame [Status: UPDATE_STATE_NODE_INFO_RECEIVED, Node ID: 2, Device Classes: [Basic: BASIC_TYPE_ROUTING_SLAVE, Generic: GENERIC_TYPE_SWITCH_BINARY, Specific: SPECIFIC_TYPE_POWER_SWITCH_BINARY], Command Classes: [Supported: [COMMAND_CLASS_SWITCH_BINARY, COMMAND_CLASS_SWITCH_ALL, COMMAND_CLASS_POWERLEVEL, COMMAND_CLASS_CONFIGURATION, COMMAND_CLASS_VERSION, COMMAND_CLASS_MANUFACTURER_SPECIFIC, COMMAND_CLASS_NODE_NAMING], Controlled: [ – ]]] has been received.
Switch manually turned off (looks the same to me):
DEBUG 2016-07-02 16:40:00,384 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-07-02 16:40:00,386 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x10, 0x00, 0x49, 0x84, 0x02, 0x0A, 0x04, 0x10, 0x01, 0x25, 0x27, 0x73]
DEBUG 2016-07-02 16:40:00,387 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x70, 0x86, 0x72, 0x77, 0xBD]
DEBUG 2016-07-02 16:40:00,389 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x10, 0x00, 0x49, 0x84, 0x02, 0x0A, 0x04, 0x10, 0x01, 0x25, 0x27, 0x73, 0x70, 0x86, 0x72, 0x77, 0xBD] has been received.
DEBUG 2016-07-02 16:40:00,392 (Z-Wave): RX_Session_Layer : ‘Application Controller Update’ frame [Status: UPDATE_STATE_NODE_INFO_RECEIVED, Node ID: 2, Device Classes: [Basic: BASIC_TYPE_ROUTING_SLAVE, Generic: GENERIC_TYPE_SWITCH_BINARY, Specific: SPECIFIC_TYPE_POWER_SWITCH_BINARY], Command Classes: [Supported: [COMMAND_CLASS_SWITCH_BINARY, COMMAND_CLASS_SWITCH_ALL, COMMAND_CLASS_POWERLEVEL, COMMAND_CLASS_CONFIGURATION, COMMAND_CLASS_VERSION, COMMAND_CLASS_MANUFACTURER_SPECIFIC, COMMAND_CLASS_NODE_NAMING], Controlled: [ – ]]] has been received.
Other than following the how-to instructions in the OpenRemote Designer documentation for setting up a simple Z-wave on/off switch/sensor, is there something else I’m missing or that I can look at? The switch status does reflect properly when I use, say, a button on the web console interface to control the switch, just not when I hit it manually.
I have a garage door sensor that does actually reflect the status properly when it changes.
Thanks!
