Hello!
I have been trying to set up a tracking service for a long time and came across with openremote.
I have got a hand full of Teltonika FMC920s and FMC230s.
Setup was starigt forward using the guide, I run this in a docker image on a windows machine.
I was able to connect one of each type and get some data without location as I am sitiing inside.
So I went ahead and started doing what is written in the “Developer Guide: Working on maps” and watched the video on YouTube “How to: white labeling of your free open source IoT platform” here I have jumped right to the part where he is talking about the custom map.
Since than I have a nice map which is for some reasons not even centered (I have the right coordinates)
But I did not get any data form the devices, even tried a new one and the following error pops up in the docker logs:
2024-11-05 23:05:49 manager-1 | 2024-11-05 23:05:49.225 INFO [Thread-0 (ActiveMQ-serve..7fc)] nager.mqtt.ActiveMQORSecurityManager.API : Un-supported request sub: topic=master/002/867747072572702/commands, connection=/172.20.0.5:34364, clientID=867747072572702, subject=anonymous
2024-11-05 23:05:50 manager-1 | 2024-11-05 23:05:50.708 INFO [Thread-1 (ActiveMQ-serve..7fc)] nager.mqtt.ActiveMQORSecurityManager.API : Un-supported request pub: topic=master/002/867747072572702/data, connection=/172.20.0.5:34364, clientID=867747072572702, subject=anonymous
2024-11-05 23:05:50 manager-1 | 2024-11-05 23:05:50.709 SEVERE [Thread-1 (ActiveMQ-serve..7fc)] ache.activemq.artemis.core.protocol.mqtt : AMQ834002: Error processing control packet: MqttPublishMessage[fixedHeader=MqttFixedHeader[messageType=PUBLISH, isDup=false, qosLevel=AT_MOST_ONCE, isRetain=false, remainingLength=249], variableHeader=MqttPublishVariableHeader[topicName=master/002/867747072572702/data, packetId=-1], payload=PooledSlicedByteBuf(ridx: 0, widx: 216, cap: 216/216, unwrapped: PooledUnsafeDirectByteBuf(ridx: 252, widx: 252, cap: 1024))]
2024-11-05 23:05:50 manager-1 | ActiveMQSecurityException[errorType=SECURITY_EXCEPTION message=AMQ229032: User: null does not have permission='SEND' on address master.002.867747072572702.data]
2024-11-05 23:05:50 manager-1 | at org.apache.activemq.artemis.core.security.impl.SecurityStoreImpl.check(SecurityStoreImpl.java:315)
2024-11-05 23:05:50 manager-1 | at org.apache.activemq.artemis.core.server.impl.ServerSessionImpl.securityCheck(ServerSessionImpl.java:509)
2024-11-05 23:05:50 manager-1 | at org.apache.activemq.artemis.core.server.impl.ServerSessionImpl.doSend(ServerSessionImpl.java:2301)
2024-11-05 23:05:50 manager-1 | at org.apache.activemq.artemis.core.server.impl.ServerSessionImpl.send(ServerSessionImpl.java:1934)
2024-11-05 23:05:50 manager-1 | at org.apache.activemq.artemis.core.server.impl.ServerSessionImpl.send(ServerSessionImpl.java:1873)
2024-11-05 23:05:50 manager-1 | at org.apache.activemq.artemis.core.protocol.mqtt.MQTTPublishManager.sendToQueue(MQTTPublishManager.java:241)
2024-11-05 23:05:50 manager-1 | at org.apache.activemq.artemis.core.protocol.mqtt.MQTTProtocolHandler.handlePublish(MQTTProtocolHandler.java:322)
2024-11-05 23:05:50 manager-1 | at org.apache.activemq.artemis.core.protocol.mqtt.MQTTProtocolHandler.act(MQTTProtocolHandler.java:162)
2024-11-05 23:05:50 manager-1 | at org.apache.activemq.artemis.utils.actors.Actor.doTask(Actor.java:32)
2024-11-05 23:05:50 manager-1 | at org.apache.activemq.artemis.utils.actors.ProcessorBase.executePendingTasks(ProcessorBase.java:68)
2024-11-05 23:05:50 manager-1 | at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
2024-11-05 23:05:50 manager-1 | at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
2024-11-05 23:05:50 manager-1 | at org.apache.activemq.artemis.utils.ActiveMQThreadFactory$1.run(ActiveMQThreadFactory.java:118)
So I am a big clueless at his point. Not to mention this is my first docker experience as well.
And comment is highly appreciated that might move us forward.
Greetings,
Zoszko
