hi,
i am having trouble with the Zstick Gen 5. When i use it with Homegenie (on this same ubuntu computer) it seems to recognize the port and z-stick and get messages back from my garage door sensor. log files show the following error
INFO 2016-06-02 11:28:14,527 (Z-Wave):
Here are a few steps to make sure that the serial port in combination with OpenRemote Controller 2.0.X is running on Linux:
Update RXTX
sudo apt-get install librxtx-java
cp /usr/lib/jni/librxtxSerial.so [path to OpenRemote Controller]/\
OpenRemote-Controller-2.0.2/webapps/controller/WEB-INF/lib/native/librxtxSerial.so
Check if user is part of dialout group
id
Add user to dialout group
sudo usermod -a -G dialout username
Make sure the serial port is recognized by RXTX library
Thanks for the quick response! I will give this a try
