Good afternoon everyone, I don’t know if it only happens to me but this is happening to me:
This week I started working with the OR sdk in Android Studio. I have the problem that I cannot connect to either the OR Demo (Smartcity and Manufacturer) or the custom implementation that I have. I tried installing and uninstalling from my Samsung A50 android phone and from Andoird Studio and I have the same error.
Android SDK August 22, 2023
I install APP
I open it and accept the policies
Enter the domain: demo
Enter the realm: smartcity
Blank screen
Is anyone experiencing the same error?
Thank you very much. Mariano.
pdw
September 13, 2023, 6:26pm
2
Hi mbrizu74,
Yes, I came to this forum to look for answers. I face the same issue.
You can reproduce the issue with the Google Play app and the demo on the openremote website. Follow steps 1
to 4
, but make sure in step 3
you add https://demo.openremote.app
I get in step 5 the same blank white screen even if I compiled the app myself.
A second issue, maybe entirely unrelated, is the stock app in the openremote repository on location ~/openremote/console/android/GenericApp/ does not compile. I will post the reproduction of this issue later and the “potential” fix.
Hi all!
Yes we just discovered the issue in the OR team as well.
We’re investigating and busy with working on a fix!
If you have any logs or errors to share please do!
That will help us get to the cause quicker
Hi Martin. I attach the debug of the app in Android Studio
2023-09-14 10:11:55.723 634-667 EGL_emulation io.openremote.app D app_time_stats: avg=17439.15ms min=29.60ms max=34848.70ms count=2
---------------------------- PROCESS ENDED (634) for package io.openremote.app ----------------------------
---------------------------- PROCESS STARTED (968) for package io.openremote.app ----------------------------
2023-09-14 10:12:21.283 968-968 ApplicationLoaders io.openremote.app D Returning zygote-cached class loader: /system_ext/framework/androidx.window.extensions.jar
2023-09-14 10:12:21.284 968-968 ApplicationLoaders io.openremote.app D Returning zygote-cached class loader: /system_ext/framework/androidx.window.sidecar.jar
2023-09-14 10:12:21.301 968-968 ziparchive io.openremote.app W Unable to open '/data/app/~~SGqjcDZHrBtyp7Vf7RBBEg==/io.openremote.app-uivs9KFpmRZjt4ZYht6ZtA==/base.dm': No such file or directory
2023-09-14 10:12:21.302 968-968 ziparchive io.openremote.app W Unable to open '/data/app/~~SGqjcDZHrBtyp7Vf7RBBEg==/io.openremote.app-uivs9KFpmRZjt4ZYht6ZtA==/base.dm': No such file or directory
2023-09-14 10:12:21.983 968-968 nativeloader io.openremote.app D Configuring clns-6 for other apk /data/app/~~SGqjcDZHrBtyp7Vf7RBBEg==/io.openremote.app-uivs9KFpmRZjt4ZYht6ZtA==/base.apk. target_sdk_version=33, uses_libraries=, library_path=/data/app/~~SGqjcDZHrBtyp7Vf7RBBEg==/io.openremote.app-uivs9KFpmRZjt4ZYht6ZtA==/lib/x86_64, permitted_path=/data:/mnt/expand:/data/user/0/io.openremote.app
2023-09-14 10:12:22.027 968-968 GraphicsEnvironment io.openremote.app V Currently set values for:
2023-09-14 10:12:22.028 968-968 GraphicsEnvironment io.openremote.app V angle_gl_driver_selection_pkgs=[]
2023-09-14 10:12:22.029 968-968 GraphicsEnvironment io.openremote.app V angle_gl_driver_selection_values=[]
2023-09-14 10:12:22.034 968-968 GraphicsEnvironment io.openremote.app V ANGLE GameManagerService for io.openremote.app: false
2023-09-14 10:12:22.035 968-968 GraphicsEnvironment io.openremote.app V io.openremote.app is not listed in per-application setting
2023-09-14 10:12:22.037 968-968 GraphicsEnvironment io.openremote.app V Neither updatable production driver nor prerelease driver is supported.
2023-09-14 10:12:22.094 968-968 Compatibil...geReporter io.openremote.app D Compat change id reported: 183155436; UID 10187; state: ENABLED
2023-09-14 10:12:22.157 968-968 FirebaseApp io.openremote.app I Device unlocked: initializing all Firebase APIs for app [DEFAULT]
2023-09-14 10:12:22.251 968-968 FirebaseInitProvider io.openremote.app I FirebaseApp initialization successful
2023-09-14 10:12:22.339 968-998 libEGL io.openremote.app D loaded /vendor/lib64/egl/libEGL_emulation.so
2023-09-14 10:12:22.353 968-998 libEGL io.openremote.app D loaded /vendor/lib64/egl/libGLESv1_CM_emulation.so
2023-09-14 10:12:22.381 968-998 libEGL io.openremote.app D loaded /vendor/lib64/egl/libGLESv2_emulation.so
2023-09-14 10:12:24.049 968-968 WebViewFactory io.openremote.app I Loading com.google.android.webview version 113.0.5672.136 (code 567263637)
2023-09-14 10:12:24.068 968-968 ziparchive io.openremote.app W Unable to open '/data/app/~~CKE9PDql0mrmeikslQ4acg==/com.google.android.trichromelibrary_567263637-FRSgKZQMnskogm_4cS7GIw==/TrichromeLibrary.dm': No such file or directory
2023-09-14 10:12:24.070 968-968 .openremote.app io.openremote.app W Entry not found
2023-09-14 10:12:24.080 968-968 nativeloader io.openremote.app D Configuring clns-7 for other apk /data/app/~~CKE9PDql0mrmeikslQ4acg==/com.google.android.trichromelibrary_567263637-FRSgKZQMnskogm_4cS7GIw==/TrichromeLibrary.apk. target_sdk_version=34, uses_libraries=ALL, library_path=/data/app/~~x3UR4B5GGYT8Ri3UI5zfbA==/com.google.android.webview-sFFGjwuu53GN4iFcShN1Qw==/lib/x86_64:/data/app/~~x3UR4B5GGYT8Ri3UI5zfbA==/com.google.android.webview-sFFGjwuu53GN4iFcShN1Qw==/WebViewGoogle.apk!/lib/x86_64:/data/app/~~CKE9PDql0mrmeikslQ4acg==/com.google.android.trichromelibrary_567263637-FRSgKZQMnskogm_4cS7GIw==/TrichromeLibrary.apk!/lib/x86_64, permitted_path=/data:/mnt/expand
2023-09-14 10:12:24.103 968-968 nativeloader io.openremote.app D Configuring clns-8 for other apk /data/app/~~x3UR4B5GGYT8Ri3UI5zfbA==/com.google.android.webview-sFFGjwuu53GN4iFcShN1Qw==/WebViewGoogle.apk. target_sdk_version=34, uses_libraries=, library_path=/data/app/~~x3UR4B5GGYT8Ri3UI5zfbA==/com.google.android.webview-sFFGjwuu53GN4iFcShN1Qw==/lib/x86_64:/data/app/~~x3UR4B5GGYT8Ri3UI5zfbA==/com.google.android.webview-sFFGjwuu53GN4iFcShN1Qw==/WebViewGoogle.apk!/lib/x86_64:/data/app/~~CKE9PDql0mrmeikslQ4acg==/com.google.android.trichromelibrary_567263637-FRSgKZQMnskogm_4cS7GIw==/TrichromeLibrary.apk!/lib/x86_64, permitted_path=/data:/mnt/expand
2023-09-14 10:12:24.264 968-968 .openremote.app io.openremote.app W Accessing hidden method Landroid/os/Trace;->isTagEnabled(J)Z (unsupported, reflection, allowed)
2023-09-14 10:12:24.265 968-968 .openremote.app io.openremote.app W Accessing hidden method Landroid/os/Trace;->traceBegin(JLjava/lang/String;)V (unsupported, reflection, allowed)
2023-09-14 10:12:24.265 968-968 .openremote.app io.openremote.app W Accessing hidden method Landroid/os/Trace;->traceEnd(J)V (unsupported, reflection, allowed)
2023-09-14 10:12:24.265 968-968 .openremote.app io.openremote.app W Accessing hidden method Landroid/os/Trace;->asyncTraceBegin(JLjava/lang/String;I)V (unsupported, reflection, allowed)
2023-09-14 10:12:24.266 968-968 .openremote.app io.openremote.app W Accessing hidden method Landroid/os/Trace;->asyncTraceEnd(JLjava/lang/String;I)V (unsupported, reflection, allowed)
2023-09-14 10:12:24.284 968-968 cr_WVCFactoryProvider io.openremote.app I Loaded version=113.0.5672.136 minSdkVersion=29 isBundle=false multiprocess=true packageId=2
2023-09-14 10:12:24.316 968-1007 cr_VariationsUtils io.openremote.app I Failed reading seed file "/data/user/0/io.openremote.app/app_webview/variations_seed_new"
2023-09-14 10:12:24.317 968-1007 cr_VariationsUtils io.openremote.app I Failed reading seed file "/data/user/0/io.openremote.app/app_webview/variations_seed"
2023-09-14 10:12:24.342 968-968 cr_LibraryLoader io.openremote.app I Successfully loaded native library
2023-09-14 10:12:24.345 968-968 cr_CachingUmaRecorder io.openremote.app I Flushed 8 samples from 8 histograms.
2023-09-14 10:12:24.755 968-968 Compatibil...geReporter io.openremote.app D Compat change id reported: 214741472; UID 10187; state: ENABLED
2023-09-14 10:12:24.761 968-968 Compatibil...geReporter io.openremote.app D Compat change id reported: 171228096; UID 10187; state: ENABLED
2023-09-14 10:12:24.858 968-968 AutofillManager io.openremote.app D Fill dialog is enabled:false, hints=[password, passwordAuto, creditCardNumber, creditCardSecurityCode, creditCardExpirationDate]
2023-09-14 10:12:24.919 968-968 OrMainActivity io.openremote.app I Enabling remote debugging
2023-09-14 10:12:24.943 968-968 Compatibil...geReporter io.openremote.app D Compat change id reported: 237531167; UID 10187; state: DISABLED
2023-09-14 10:12:24.947 968-968 OpenGLRenderer io.openremote.app W Unknown dataspace 0
2023-09-14 10:12:25.006 968-968 OrMainActivity io.openremote.app I Connectivity changed: true
2023-09-14 10:12:25.011 968-968 Compatibil...geReporter io.openremote.app D Compat change id reported: 193247900; UID 10187; state: ENABLED
2023-09-14 10:12:25.126 968-996 OpenGLRenderer io.openremote.app W Failed to choose config with EGL_SWAP_BEHAVIOR_PRESERVED, retrying without...
2023-09-14 10:12:25.126 968-996 OpenGLRenderer io.openremote.app W Failed to initialize 101010-2 format, error = EGL_SUCCESS
2023-09-14 10:12:25.155 968-996 Gralloc4 io.openremote.app I mapper 4.x is not supported
2023-09-14 10:12:25.221 968-996 OpenGLRenderer io.openremote.app E Unable to match the desired swap behavior.
2023-09-14 10:12:26.619 968-996 EGL_emulation io.openremote.app D app_time_stats: avg=425.84ms min=29.26ms max=1095.42ms count=3
Hi guys!
We released a new version of the OpenRemote app on the Google Play store.
The issue should be solved. Can you check?
Hi Martin
It works perfect. Thank you so much. Notify when the Github repository is updated.
