You can create rules to match a sensor value and push whatever string you like into another command, which can then be picked up by another sensor command.
I use in memory commands to hold strings.
For example.
If an external sensor changes or is matched in a rule, a string will be pushed into an in-memory command for use later.
As for "regular expression", it's a dark art I don't understand, but it's a way of stripping out a required value from a longer bit of text.
For example, you might get a full XML formatted return from a device, where you only want a tiny part.
A regular expression will / can cause the sensor to only show that required part.
I'd suggest posting a copy of the full text your sensor is returning and ask for help formatting a regular expression.
(FYI, there are a number of posts on this subject already)
Thanks for the inputs.
basically what i am trying to achieve is conceptually fairly simple. I have a UDP listener sensor that is taking values from Ha-bridge to turn on lights. That part is working fine. What i want to do is reset the value of that UDP sensor are 1800 seconds
I have have two rules as follows. The first one works fine. The second one does not give any errors but the value of the sensor does not change:
rule “Alexa mute on”
when
Event( source == “habridge mute on sensor”, value == “muteon”) --------->> This is a UDP listener sensor
then
execute.command( “Mute audio on” ); --------->> --------->> This is a in-memory virtual command
end
rule “Alexa mute audio reset”
timer (int: 1800s 0s)
when
Event( source == “Mute audio sensor”, value == “on” ) ---------------->> This is a in-memory virtual command sensor
then
execute.command( “habridge mute on”, “muteoff” ); ------------------->> This is a UDP listener Command tied to UDP listener sensor ( THIS PART IS NOT WORKING, after 1800s i want the UDPL sensor to get value “muteoff” assigned)
First of all, your timer expression should have only the delay, no repeat statement. Moreover, repeat of 0s is not valid. So it should look like:
timer(int: 1800s)
Moreover, you are using 2 sensors ( “habridge mute on sensor” and “Mute audio sensor”) and 2 commands (“Mute audio on” and “habridge mute on”). You are checking “Mute audio sensor” on value “on”, but it is case sensitive and could be also “ON”. Therefore, without seeing its command definition it is impossible to judge if the case is correct.
Usually, the best way to get an accurate answer is to send all relevant info. Beside of your not working rules snippet also commands and sensors definitions.
i tried changing the timer(int: 10s) and didn’t seem to make a difference. The command had “ON” and the in the rule i was using “on” so i changed them to match. However, it does not seem to be making a difference as well. I have attached a couple o f screen shots showing the commands and sensors. I am wondering if a value can be assigned to a udpl sensor from a rule
Here are modified rules:
when
then
end
rule “Alexa mute off”
when
Event( source == “habridge mute on sensor”, value == “muteoff”)
then
execute.command( “Mute audio off” );
end
timer (int: 10s)
when
Event( source == “Mute audio sensor”, value == “ON” )
then
execute.command( “habridge mute on”, “muteoff” );-------> “muteoff” IS NOT GETTING assigned to “habridge mute on sensor”
