i added an attributes with configuration items and i added a flow rule to get the result but I don’t get any result from the rule.
It worked before but not anymore.
Here is my attribute with configuration items
Could you also show the rule and explain the attributes involved a bit?
Thanks @Don for your answer.
I noticed that I had added a rule that was not correct and this prevents all the rules from being executed.
