Attribute Links with value modification
I’m using Attribute Links configuration option to populate asset attributes from another JSON attribute linked with MQTTLink Agent and it works fine. My Attribute Links JSON:
    "ref": {
      "id": "5mEPbDgAIcTae1eI14DqGP",
      "name": "temperatura_akt"
    "filters": [
        "type": "jsonPath",
        "path": "$.object.TempC_SHT31",
        "returnFirst": true,
        "returnLast": false
Currently I want to populate this attribute (“temperatura_akt”) with value returned from MQTTLink but additionaly I want to sum it with a another attribute value (“delta_callib_temp”). “delta_callib_temp” attribute is defined within the same asset as “temperatura_akt”.
So finally (in pseudocode)
asset.temperatura_akt.value=$.object.TempC_SHT31+asset.delta_callib_temp.value
Is it possible?
I’ve tried to use Flow Rule, rule works but since “temperatura_akt” is “date point” attribute it creates new value for it instead of just update and on “History” chart for “temperatura_akt” we have 2 values for one MQTTLink action (value passed from AgentLink and few secs later new value generated by rule). So I think we need to somehow modify value in “Attribute Links” option
Currently there is no support for summing values using Attribute links.
From my experience, your only option is to use Flow rules here.
Funny enough, I had a chat with @panos about this recently,
where he shared his ideas on this. :joy:
Because I saw this topic coming by, I wanted to share this is somewhat supported nowadays :wink:
You can add a Mathematical expression for a single attribute in an attribute filter like this;
    "ref": {
      "id": "4ueyx00j4nAQJoqYK7WaKt",
      "name": "myattributename"
    "filters": [
        "type": "mathExpression",
        "expression": "x*2"
