Auto provisioned device MQTT attribute write
Hello, I’ve installed OpenRemote and managed to get the Auto Provisioning setup but after I provision a new device I can’t seem to understand how I’m supposed to update attributes from that asset. I’ve tried using MQTTX ( same one I used for provisioning ) to send a write attribute using same certificate I used to enroll but nothing happens, nothing in logs and no data.
Topic: master/TestDevice/writeattributevalue/test/6ZTXcBysubWnSoxcHkzmvkQoS: 0
“hello world”
I think this is a similar post to what issue I’m having:
Anyway somebody could help me out and explain what I’m doing wrong ?
Thank you !
Hi Francnatic,
What the poster in the topic you mention seemed to miss, is that the auto-provisioning mqtt session is the one you also use for pub/sub.
So everytime you want the device to connect you follow the auto-provisioning flow by publishing the certificate to the auto provisioning topic. After that, you can publish to another topic during that session.
