Auto provisioning devices from AWS IoT Core
Hi all,
I am exploring OpenRemote and looking for a solution that I can auto provision devices from AWS IoT Core MQTT.
I am using Thingsboard for IoT management and I can achieve this by using Thingsboard IoT gateway or the AWS Integration in ThingsBoard PE. I setup the MQTT Agent but it seem not work the same way as Thingsboard IoT gateway.
I am consider to move to OpenRemote so I am wondering if I can do the same setup in OpenRemote.
In my setup, I use AWS IoT Core as the device ingress, and the PKI will be done in AWS IoT Core. The device then will be auto provisioned by mapping a field in payload to device name.
Thank you all and appriaciate if oneany one can give me some idea to resolve this with OpenRemote
First of all, welcome to the forum!
You can look on the documentation website, which has plenty of information on
how to auto provision a device through MQTT.
