I installed Openremote on a VPS with Ubuntu 22.04. I’m using the latest docker-compose.yml file from github.
My VPS has a public IP x.x.x.x , so I am starting with the following:
OR_HOSTNAME=x.x.x.x OR_SSL_PORT=8443 docker-compose -p openremote up -d
or
OR_HOSTNAME=x.x.x.x docker-compose -p openremote up -d
All goes well. Containers are up and running (checked with docker ps -a).
However, when accessing https://x.x.x.x:8443/ using GoogleChrome, I get the following:
This site can’t be reached
x.x.x.x refused to connect.
Try:
Checking the connection
Checking the proxy and the firewall
ERR_CONNECTION_REFUSED
I was able to run a basic install on local machine / localhost, but I am really lost on VPS. I was also having a clean install, with web server up an running and I could access http://x.x.x.x . Sure, I was stopping apache once I started docker, to avoid any port conflict.
TLS protocol would not work with a bare public IP. You’ll need to have a domain name and configure its DNS zone to point a some domain valid name to your public IP. Usually, you need to create an A or AAAA record inside the DNS zone to do this.
I was trying it with domain name as well, creating first an A record inside the DNS zone. Still same behaviour. I guess my problem would be the correct config of the docker-compose file.
Ca you point to any “template” or example I can use? I am now using this one from Quickstart instructions.
An ERR_CONNECTION_REFUSED is typically a TCP-RST packet received from the server by the browser. In your situation, the firewall is letting TCP traffic through, and your server’s operating system answers with a TCP-RST because no server socket is bound to port 8443.
Can you confirm the error ERR_CONNECTION_REFUSED is coming immediately? Can you ensure it is not a timeout? A timeout is a firewall issue, which I assume is not the issue here. Can you confirm the error ERR_CONNECTION_REFUSED is even there if the servers are not running?
To test this hypothesis, can you run the following command? It is an independent docker server showing “It works” when properly configured.
docker run -p 8443:80 --name httpd-container httpd
Hopefully this will help a bit with troubleshooting.
The error you get now is typical. It is an HTTP server, not HTTPS. It complains about the certificate. If you go to http://x.x.x.x:8443/ it will work. But that does not bring you closer to a solution.
You have learned the following things:
Your Firewall is OK.
You can run a server
Something is seriously wrong in accepting SSL/TLS traffic on port 8443.
Maybe the fastest solution is to buy a new VPS with a dedicated IP and stick to the standard settings used by 99% of the users. If that is not possible, please familiarize yourself with the art of configuring haproxy as a reverse proxy for your other services working currently on your current server. So Openremote and your original services can coexist on the same system.
