Hello
I’m having trouble with the 2.6.0 beta3 controller
I am using java 8
By the time I have the rules that does not work anymore.
in the log y 'has this error which appears:
2017-11-07 18:17:31,914 ERROR [Polling Sensor Thread ID = 100118, Name =‘virtual_volet_salon_status’]: Error in executing rule : virtual_volet_salon_status:java.lang.Integer cannot be cast to java.lang.String
Event org.openremote.controller.model.event.CustomState@88f8eeca not processed!
java.lang.ClassCastException: java.lang.Integer cannot be cast to java.lang.String
at java.lang.String.compareTo(String.java:111)
at ConditionEvaluator39b0ecb05ada40729038151938a5ae45.evaluate(Unknown Source)
at org.drools.core.rule.constraint.MvelConstraint.evaluate(MvelConstraint.java:258)
at org.drools.core.rule.constraint.MvelConstraint.isAllowedCachedLeft(MvelConstraint.java:226)
at org.drools.core.common.SingleBetaConstraints.isAllowedCachedLeft(SingleBetaConstraints.java:138)
at org.drools.core.phreak.PhreakJoinNode.doLeftInserts(PhreakJoinNode.java:113)
at org.drools.core.phreak.PhreakJoinNode.doNode(PhreakJoinNode.java:76)
at org.drools.core.phreak.RuleNetworkEvaluator.switchOnDoBetaNode(RuleNetworkEvaluator.java:519)
at org.drools.core.phreak.RuleNetworkEvaluator.evalBetaNode(RuleNetworkEvaluator.java:505)
at org.drools.core.phreak.RuleNetworkEvaluator.evalNode(RuleNetworkEvaluator.java:341)
at org.drools.core.phreak.RuleNetworkEvaluator.innerEval(RuleNetworkEvaluator.java:301)
at org.drools.core.phreak.RuleNetworkEvaluator.outerEval(RuleNetworkEvaluator.java:136)
at org.drools.core.phreak.RuleNetworkEvaluator.evaluateNetwork(RuleNetworkEvaluator.java:94)
at org.drools.core.phreak.RuleExecutor.reEvaluateNetwork(RuleExecutor.java:194)
at org.drools.core.phreak.RuleExecutor.evaluateNetworkAndFire(RuleExecutor.java:73)
at org.drools.core.common.DefaultAgenda.fireNextItem(DefaultAgenda.java:1007)
at org.drools.core.common.DefaultAgenda.fireLoop(DefaultAgenda.java:1350)
at org.drools.core.common.DefaultAgenda.fireAllRules(DefaultAgenda.java:1288)
at org.drools.core.impl.StatefulKnowledgeSessionImpl.internalFireAllRules(StatefulKnowledgeSessionImpl.java:1306)
at org.drools.core.impl.StatefulKnowledgeSessionImpl.fireAllRules(StatefulKnowledgeSessionImpl.java:1297)
at org.drools.core.impl.StatefulKnowledgeSessionImpl.fireAllRules(StatefulKnowledgeSessionImpl.java:1278)
at org.openremote.controller.statuscache.rules.RuleEngine.push(RuleEngine.java:203)
at org.openremote.controller.statuscache.EventProcessorChain.push(EventProcessorChain.java:196)
at org.openremote.controller.statuscache.StatusCache.update(StatusCache.java:293)
at org.openremote.controller.model.sensor.Sensor.update(Sensor.java:367)
at org.openremote.controller.model.sensor.Sensor$DeviceReader.run(Sensor.java:655)
at java.lang.Thread.run(Thread.java:744)
2017-11-07 18:17:41,929 ERROR [Polling Sensor Thread ID = 100266, Name =‘thermostat_varia’]: Error in executing rule : thermostat_varia:java.lang.Integer cannot be cast to java.lang.String
Event Range Event (ID = 100266, Source = ‘thermostat_varia’, Value = ‘15’, Boundaries = [15…30]) not processed!
at ConditionEvaluatorb7240dd69dd44b86906e848648e42427.evaluate(Unknown Source)
2017-11-07 18:17:41,934 ERROR [Polling Sensor Thread ID = 100291, Name =‘VKEY4’]: Error in executing rule : VKEY4:java.lang.Integer cannot be cast to java.lang.String
Event org.openremote.controller.model.event.CustomState@4e092ee not processed!
2017-11-07 18:19:28,634 ERROR [Polling Sensor Thread ID = 100266, Name =‘thermostat_varia’]: Error in executing rule : thermostat_varia:java.lang.Integer cannot be cast to java.lang.String
Event Range Event (ID = 100266, Source = ‘thermostat_varia’, Value = ‘22’, Boundaries = [15…30]) not processed!
