Hi everyone,
I’m running the test suite in my fork of OpenRemote. “./gradlew clean installDist” is working but 2 out of the 175 tests are failing for “./gradlew test”. I’m running these locally.
Environment details:
- Java version: 21.0.6
- Node version: 20.11.1
- Yarn version: 4.1.0
- Gradle version: 8.13
- Docker Compose: Used profile/dev-testing.yml
My build is successful but has a few warnings like:
I’m unsure whether these warnings might be causing the failures.
Results of running tests:
The two tests that failed:
Gradle´s problem report:
I am unsure if these failures are potentially a result of running the test suite locally or if there is another issue, maybe with dependencies. Any help is greatly appreciated. Thanks!
