Can’t send checkbox value when using MQTT Agent Link
"believerGuarantee":"RECEIPT_CONFIRMATION",
"command":"relayWrite",
"data": {
"pinNumber": 1,
"pinValue" : {{value}}
"type": "jsonPath",
"path": "$.data.pinValue",
"returnFirst": true,
"returnLast": true
Are templates used for MQTT Agent Link
Templates are supported when sending data. You need to add a Write Value parameter to the MQTT Agent Link using %VALUE% as the placeholder format. In your case, the configuration should look like this:
"data": {
"pinNumber": 1,
"pinValue" : %VALUE%
You might also need to add a Write Value Converter to the MQTT Agent Link, but that depends on the format required for the pinValue .
Thanks, it worked.
Could you please tell me why after successful sending the message appears under the checkbox: “Send failed”
system
Closed
July 8, 2026, 7:24am
4
