Dear openremote'ers,
I'm trying to send various data to one of the memories in a 1-wire DS2438 device. I intend to do this by using "execute.command" in a rule RHS with two parameters. I am using the stripped-down test configuration below. I monitor the page.3 memory by accessing the DS2438 with my browser.
I use the browser to set the 8-byte memory to all-zero. I reboot the raspberry pi. The memory remains all-zero. I "push" the button on the iPhone and "ABC" appears in the memory (4142430000000000 actually).
Further button pushes do not put "999" into the memory. If I change the "Data to send" in the command to none (empty), I get a "java.lang.NullPointerException" in openremote/logs/dev.log.
(see http://www.gizmology.com/dev.log
I sure would like to get this working... Even though openremote is open source, I really don't have the java skills to dig in and make a fix... Worse yet, I have no idea how to rebuild the program if I found a fix.
Help??
BTW: I can READ the memory location display it on the iPhone.
73,
Gary
-------- COMMAND ----------------
Name: Send page data
Protocol: 1-wire Protocol
Hostname: 192.168.1.181
Port: 4304
Device address: SprinkIPC/pages
Sensor attribute: page.3
Temp. scale:
Polling interval: 3s
Data to send: ABC
Protocol: In-Memory Virtual Command
Command: on
Address: testbutton
-------- SENSOR -----------------
Command: Catch Button
Type: custom
Custom State Items: (empty)
-------- BUTTON -----------------
-------- RULES ------------------
rule "Send to page.3"
when
Event(source=="Button Sense", value=="on")
then
execute.command("Send page data", "999");
end
