I have an existing, working design in OpenRemote Designer and I only needed to create a new OpenRemote Controller based on a Raspberry Pi 2
I installed Jessie Operating System and upgraded to latest version with apt-get upgrade
oracle-java8-jdk was already the latest version installed
I installed Openremote Controller 2.5 in /opt/openremote
I started the OpenRemote Controller via sudo /opt/openremote/bin/openremote.sh start
In OpenRemote Designer, I linked to the correct MAC address of the Controller
In my Browser, I connected to the OpenRemote Controller via http://10.4.1.74:8688/controller and got the usual dialog box got to enter my login credentials
However, when I try and sync OpenRemote Designer, I get the following error msg:
The path 'file:/../webapps/controller' doesnt exist.
Your resource.path is configured as
resource.path=…/webapps/controller
in your config.properties file.
Controller will try to resolve this based on your current working directory when starting up.
So either go to /opt/openremote/bin and do a ./openremote.sh start (or run), either update your config.properties to use absolute path.
The SystemD method of starting OpenRemote now works perfectly
If anyone is interested, here is a copy of the text from the service file, from /etc/systemd/system
Please note that I setup a SymLink from /opt/OR-Pro to wherever my OpenRemote 2.x instance is located, but the Absolute path within config.properties is that of the OpenRemote 2.x installation
Hello, excuse my newbieness as this is the first attempt at any type of open source for me. I have this same error The path ‘file:/…/webapps/controller’ doesnt exist. when trying to login and cannot figure out how to get around it. I have linked my Designer to the correct Controller and all.
