Hi everyone ,
I’ve installed Openremote with localhost.
Now I would like to change the localhost by my own host name. My host name corresponds to a website. What is the best way to use it as host name?
That looks like SSL generation has worked and the web server is responding, not sure why you are getting a 404 response, can you verify that you can access the following on your docker host:
curl -k https://localhost/manager/
I would look at docker container logs for any obvious clues and obviously check all containers are running and healthy.
P.S.keycloak:latest now uses keycloak 18.x and various environment variables have changed but the main ones should be the same.
That tells me OpenRemote is running successfully and probably your DNS is pointing to the wrong server or something…never seen a 404 page like that come from our system.
Hi @Rich,
I think I don’t understand how the domain name change works.
Let’s say I have a domain name testiot.webstarts.com that corresponds to a website and is accessible via google. Is it possible to use this domain name to access the Openremote platform?
