I am currently trying to integrate ChirpStack with OpenRemote, but I have not been able to get device discovery working correctly.
According to the documentation, I have added the following tag to my ChirpStack devices:
openremote-asset-type = ThingAsset
However, when uplink messages are received, the devices are not automatically created in OpenRemote.
Interestingly, if I use a non-existent asset type, for example:
openremote-asset-type = Hello
OpenRemote does attempt to discover the device and reports an error indicating that the asset type “Hello” is unknown. This suggests that OpenRemote is receiving and processing the discovery information, but it does not seem to recognize or create devices when using the valid asset type ThingAsset.
Below is an example of the MQTT message being published by ChirpStack:
application/37c6ff4f-2029-4d84-955e-9c6b0e3f1887/device/a7a76d8a6cb1e547/event/up
JSON
“deduplicationId”: “299609b9-1f91-4c50-85db-66216b0275c8”,
“time”: “2026-11-24T16:12:35.736152058+00:00”,
“deviceInfo”: {
“tenantId”: “d0e11c7b-ea98-443f-b5e0-1733e502360a”,
“tenantName”: “Desalinizadora”,
“applicationId”: “37c6ff4f-2029-4d84-955e-9c6b0e3f1887”,
“applicationName”: “7d4f2274-94fe-4faa-819b-95329d400f9f”,
“deviceProfileId”: “4439c776-22dd-41f4-8793-dbc1b8397e45”,
“deviceProfileName”: “6862e7cb-1ea0-48b3-9fe4-453b446cfed7”,
“deviceName”: “a7a76d8a6cb1e547”,
“devEui”: “a7a76d8a6cb1e547”,
“deviceClassEnabled”: “CLASS_A”,
“tags”: {
“openremote-asset-type”: “ThingAsset”
“devAddr”: “019baf40”,
“adr”: false,
“dr”: 5,
“fCnt”: 68,
“fPort”: 10,
“confirmed”: false,
“data”: “AQIDBA==”,
“object”: {
“bateria”: 2.0,
“temperatura”: 1.0
I also tried manually creating a ThingAsset with attributes corresponding to the payload:
JSON
“bateria”: 2.0,
“temperatura”: 1.0
but automatic device discovery still does not occur.
Am I missing any additional configuration required for ChirpStack device discovery? Is there a specific asset type, agent configuration, or expected payload structure required for OpenRemote to create ThingAsset devices automatically?
Any assistance would be greatly appreciated.
