After solving some serial port issues after installing Java 8 and going back to java 6 and following the information you gave the controller is starting up. (Thanks !)
The FUD14 can be controlled. But i have a lot of errors in my terminal when the controller is running.
Before the controller starts (rules are starting for the first time) I have a lot of the following error’s: (exactly the same every time)
ERROR [HTTP-Thread-15]: Requested sensor id ‘317.298’ was not found. Defaulting to ‘N/A’.
ERROR [HTTP-Thread-15]: Requested sensor id ‘317.300’ was not found. Defaulting to ‘N/A’.
ERROR [HTTP-Thread-15]: Requested sensor id ‘317.301’ was not found. Defaulting to ‘N/A’.
ERROR [HTTP-Thread-15]: Requested sensor id ‘317.302’ was not found. Defaulting to ‘N/A’.
ERROR [HTTP-Thread-15]: Requested sensor id ‘317.315’ was not found. Defaulting to ‘N/A’.
ERROR [HTTP-Thread-15]: Requested sensor id ‘317.316’ was not found. Defaulting to ‘N/A’.
ERROR [HTTP-Thread-15]: Requested sensor id ‘317.322’ was not found. Defaulting to ‘N/A’.
ERROR [HTTP-Thread-15]: Requested sensor id ‘317.323’ was not found. Defaulting to ‘N/A’.
ERROR [HTTP-Thread-15]: Requested sensor id ‘317.340’ was not found. Defaulting to ‘N/A’.
ERROR [HTTP-Thread-15]: Requested sensor id ‘317.341’ was not found. Defaulting to ‘N/A’.
ERROR [HTTP-Thread-15]: Requested sensor id ‘317.342’ was not found. Defaulting to ‘N/A’.
ERROR [HTTP-Thread-15]: CommandException occurs
org.openremote.controller.config.ControllerXMLChangedException: The content of controller.xml had changed.
at org.openremote.controller.service.impl.StatusPollingServiceImpl.queryChangedState(StatusPollingServiceImpl.java:72)
at org.openremote.controller.rest.StatusPollingRESTServlet.handleRequest(StatusPollingRESTServlet.java:239)
at org.openremote.controller.rest.RESTAPI.doPost(RESTAPI.java:174)
at org.openremote.controller.rest.RESTAPI.doGet(RESTAPI.java:127)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.openremote.controller.rest.support.json.JSONCallbackFilter.doFilter(JSONCallbackFilter.java:63)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:96)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:75)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:354)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:895)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:918)
at java.lang.Thread.run(Thread.java:695)
After starting up the controller the above message’s aren’t showed anymore.
I can switch on the light and dim the light the slider and switch are working correct images are showed good.
But in my terminal i see the following message when pressing a key light on/off
ERROR [HTTP-Thread-15]: Requested sensor id ‘317.329’ was not found. Defaulting to ‘N/A’.
WARN 2016-09-04 22:07:30,138 : Unable to connect to remote command service, retrying in 30.000 milliseconds. Connection error: Remote command service at ‘https://designer.openremote.com/ccs/rest//commands/1’ was not available or not found.
org.openremote.controller.exception.ConnectionException: Remote command service at ‘https://designer.openremote.com/ccs/rest//commands/1’ was not available or not found.
at org.openremote.controller.service.BeehiveCommandCheckService$BeehiveCommandChecker.httpRequest(BeehiveCommandCheckService.java:475)
at org.openremote.controller.service.BeehiveCommandCheckService$BeehiveCommandChecker.httpGet(BeehiveCommandCheckService.java:383)
at org.openremote.controller.service.BeehiveCommandCheckService$BeehiveCommandChecker.run(BeehiveCommandCheckService.java:249)
Arjen
