Hi guys ...
Is there any way to build a XCF file using IR Codes I have in a text file (so that I can import it into the designer) ?
Thanks for the replies !
LePousson
Hi guys ...
LePousson
Any chance that someone could reply to me ???
IIRC, the "native" IR format of OR is Lirc. You can use IrScrutinizer to
transform you text file to Lirc format. Does this solve your problem?
The XCF format is used by the (now long dead) Pronto professional
series. It consists of a zip file containing an XML file, and a bunch of
bitmap files. The XML format is quite understandable, containing the
(unencrypted) "Pronto hex" form. (As opposed to the PCF format that
contains encrypted signals, and, to my knowledge, the "encryption" used
is not known.) It appears to me that creating XCF files for the purpose
of OR import is "unnatural".
But, if it turns out that creating (crippled) XCF files is an important
issue, I think it can be done with a moderate effort. Let me know.
Greetz,
Bengt
Creating an XCF is very important as it is the only file format that OpenRemote is able to import... As I have something like 15 or 20 devices to drive, this function is essential ...
If you can help, that will be very very appreciated ...
LePousson
Hmm weird... At least previously it was able to import at least Lirc. Where is this documented? If there is only one import format, it appears strange (to say the least) to have XCF to be that only format. Can someone confirm? Eric?
Greetz,
Bengt
It depends on the IR emitting device you are using.
If you’re using a LIRC compatible device and the lircd mechanism, then you can only use LIRC files.
If you’re using a GlobalCaché or IRTrans as the device, then only XCF is supported for import.
I am using a GlobalCache iTach device (had it for 6 years) ... That’s why I need to be able to build a XCF file with all my devices IR and TCP/IP codes ..
Thanks in advance for your replies ...
LePousson
You can try to download ProntoEdit Professional from remotecentral.com,
http://www.remotecentral.com/news/545/philips_prontoedit_professional_30_posted_for_all.html
and generate XCF files with that. For importing your text files into
it, it may be feasible to import the text files into IrScrutinizer and
export that into a CCF file, which can subsequently (I think :-)) be
imported into ProntoEdit Professional.
Let us know if this works.
Thanx to Eric for the clarification.
Greetz,
Bengt
