Once again I’m trying to replicate an existing process through the HTTP API in MQTT protocol and I’m not sure if this is possible, so I decided to ask here on the forum.
In this endpoint I can create a new asset by HTTP request sending its JSON structure:
http://{{root}}/api/{{realm}}/asset
payload example:
"id" : "UUID converted base62 22bytes",
"version" : 0,
"createdOn" : 0,
"name" : "asset-name",
"accessPublicRead" : false,
"realm" : "asset-realm",
"type" : "BuildingAsset",
"path" : ["id defined base62 22bytes" ],
"attributes" : {
"area" : {
"type" : "positiveInteger",
"value" : null,
"name" : "area",
"timestamp" : 0
"notes" : {
"type" : "text",
"value" : null,
"name" : "notes",
"timestamp" : 0
"city" : {
"type" : "text",
"value" : null,
"name" : "city",
"timestamp" : 0
"street" : {
"type" : "text",
"value" : null,
"name" : "street",
"timestamp" : 0
"postalCode" : {
"type" : "text",
"value" : null,
"name" : "postalCode",
"timestamp" : 0
"location" : {
"type" : "GEO_JSONPoint",
"value" : null,
"name" : "location",
"timestamp" : 0
can I do the same through MQTT?
I verified that when creating an Asset the JSON structure sended is:
"eventType" : "asset",
"cause" : "CREATE",
"asset" : {
"id" : "7VesBAWXNhBIxF0ZNJvWBc",
"version" : 0,
"createdOn" : 0,
"name" : "New Asset",
"realm" : "master",
"type" : "ThingAsset",
"path" : [ "7VesBAWXNhBIxF0ZNJvWBc" ],
"attributes" : {
"notes" : {
"type" : "text",
"value" : null,
"name" : "notes",
"timestamp" : 0
"location" : {
"value" : null,
"timestamp" : 0
"timestamp" : 0
sended to topic:
{{realm}}/{{MQTTClientID}}/asset/{{AssetID}}
however, when trying to replicate the same scenario above (created using the UI), I get stuck with an error:
2022-08-31 15:16:18.124 WARNING [pool-11-thread-1 ] te.model.util.ValueUtil.MODEL_AND_VALUES : Failed to parse JSON
com.fasterxml.jackson.databind.exc.InvalidTypeIdException: Could not resolve type id 'asset' as a subtype of `org.openremote.model.attribute.AttributeEvent`: Class `org.openremote.model.asset.AssetEvent` not subtype of `org.openremote.model.attribute.AttributeEvent`
at [Source: (String)"{
"cause" : "CREATE",
"asset" : {
"version" : 0,
"createdOn" : 0,
"realm" : "master",
"attributes" : {
"notes" : {
"type" : "text",
"value" : null,
"name" : "notes",
"timestamp" : 0
"location" : {
"[truncated 111 chars]; line: 2, column: 17]
at com.fasterxml.jackson.databind.exc.InvalidTypeIdException.from(InvalidTypeIdException.java:43)
at com.fasterxml.jackson.databind.DeserializationContext.invalidTypeIdException(DeserializationContext.java:2073)
at com.fasterxml.jackson.databind.jsontype.impl.TypeDeserializerBase._findDeserializer(TypeDeserializerBase.java:199)
at com.fasterxml.jackson.databind.jsontype.impl.AsPropertyTypeDeserializer._deserializeTypedForId(AsPropertyTypeDeserializer.java:125)
at com.fasterxml.jackson.databind.jsontype.impl.AsPropertyTypeDeserializer.deserializeTypedFromObject(AsPropertyTypeDeserializer.java:110)
at com.fasterxml.jackson.databind.deser.BeanDeserializerBase.deserializeWithType(BeanDeserializerBase.java:1292)
at com.fasterxml.jackson.databind.deser.impl.TypeWrappedDeserializer.deserialize(TypeWrappedDeserializer.java:74)
at com.fasterxml.jackson.databind.deser.DefaultDeserializationContext.readRootValue(DefaultDeserializationContext.java:323)
at com.fasterxml.jackson.databind.ObjectMapper._readMapAndClose(ObjectMapper.java:4674)
at com.fasterxml.jackson.databind.ObjectMapper.readValue(ObjectMapper.java:3629)
at org.openremote.model.util.ValueUtil.parse(ValueUtil.java:189)
at org.openremote.model.util.ValueUtil.parse(ValueUtil.java:201)
at org.openremote.manager.mqtt.DefaultMQTTHandler.doPublish(DefaultMQTTHandler.java:374)
at org.openremote.manager.mqtt.ORInterceptHandler.onPublish(ORInterceptHandler.java:201)
at io.moquette.interception.BrokerInterceptor.lambda$notifyTopicPublished$3(BrokerInterceptor.java:134)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
at java.base/java.lang.Thread.run(Thread.java:833)
That’s when I was in doubt if I was using the correct topic, or even if there is this topic for creating assets through MQTT. As far as I’ve seen in the documentation, it seems to have only topics related to attribute state update.
What I would like to know:
- Which topic should I point to? If it exists, of course.
- Is the payload structure correct?
- If this feature doesn’t exist, where could I start to try to implement it? If it makes sense.
Any help would be appreciated, thanks.
