Dears,
could you please assist with the instructions on how to create a custom asset (custom icon, attributes etc)? i have looked through several topics in the forum but couldn’t find the right way.
Currently, you can create custom assets by writing the Java code in a Custom Project.
You can take a look at existing asset types here, and use that as inspiration.
Unfortunately there is no step-by-step guide for this.
By default, we provide this CustomAsset example in the custom project template;
package org.openremote.model.custom;
import org.openremote.model.asset.Asset;
import org.openremote.model.asset.AssetDescriptor;
import org.openremote.model.value.AttributeDescriptor;
import org.openremote.model.value.ValueDescriptor;
import jakarta.persistence.Entity;
import java.util.Optional;
* This is an example of a custom {@link Asset} type; this must be registered via an
* {@link org.openremote.model.AssetModelProvider} and must conform to the following requirements:
* <ul>
* <li>Must have {@link Entity} annotation
* <li>Optionally add {@link org.openremote.model.value.ValueDescriptor}s
* <li>Optionally add {@link org.openremote.model.value.MetaItemDescriptor}s
* <li>Optionally add {@link org.openremote.model.value.AttributeDescriptor}s
* <li>Must have a public static final {@link org.openremote.model.asset.AssetDescriptor}
* <li>Must have a protected no args constructor (for hydrators i.e. JPA/Jackson)
* <li>For a given {@link Asset} type only one {@link org.openremote.model.asset.AssetDescriptor} can exist
* <li>{@link org.openremote.model.value.AttributeDescriptor}s that override a super class descriptor cannot change the
* value type; just the formatting etc.
* <li>{@link org.openremote.model.value.MetaItemDescriptor}s names must be unique
* <li>{@link org.openremote.model.value.ValueDescriptor}s names must be unique
* </ul>
@Entity
public class CustomAsset extends Asset<CustomAsset> {
public enum CustomValueType {
ONE,
TWO,
THREE
public static final ValueDescriptor<CustomValueType> CUSTOM_VALUE_TYPE_VALUE_DESCRIPTOR = new ValueDescriptor<>("customValueType", CustomValueType.class);
public static final AttributeDescriptor<CustomValueType> CUSTOM_VALUE_TYPE_ATTRIBUTE_DESCRIPTOR = new AttributeDescriptor<>("customAttribute", CUSTOM_VALUE_TYPE_VALUE_DESCRIPTOR);
public static final AssetDescriptor<CustomAsset> CUSTOM_ASSET_ASSET_DESCRIPTOR = new AssetDescriptor<>("brightness-auto", "00aaaa", CustomAsset.class);
public Optional<CustomValueType> getCustomAttribute() {
return getAttributes().getValue(CUSTOM_VALUE_TYPE_ATTRIBUTE_DESCRIPTOR);
public CustomAsset setCustomAttribute(CustomValueType value) {
getAttributes().getOrCreate(CUSTOM_VALUE_TYPE_ATTRIBUTE_DESCRIPTOR).setValue(value);
return this;
Thanks for a prompt response.
is it possible to share steps to create a Custom asset? at least on a high level without details?
