How do I know the selected Node tree value when using 2 or-asset-trees? I have a problem: when selecting a node tree, the data is displayed in both input tags.
Can you describe or share screenshots the problem you’re encountering?
And what do you mean with “when using 2 or-asset-trees” ?
If it’s a bug, feel free to open an GitHub issue, or open a PR with a fix;
What I mean is that when I create an additional input tag that has the same function as parent when creating an asset, is there any way for me to differentiate the data when I select data in the two tags?
[image]
