Hello
I’m new to openremote and I’m currently trying to display my own map instead of the custom Rotterdam map (on https://localhost).
My main sources of information so far were the GitHub tutorial and the OpenRemote YouTube " How to: white labeling of your free open source IoT platform" tutorial.
Reviewing the openremote-manager-1 logs, it seems clear that the mapdata.mbtiles file can not be located and is therefore not displayed. The same is true for the mapsettings.json file, though the logs show a slightly different path (deployment.local vs deployment).
2023-03-23 15:28:51 2023-03-23 15:28:51.310 WARNING [main] org.openremote.manager.map.MapService: Map tiles data file not found '/deployment.local/mapdata/mapdata.mbtiles', falling back to built in map
2023-03-23 15:28:51 2023-03-23 15:28:51.311 WARNING [main] org.openremote.manager.map.MapService: Map settings file not found '/deployment/map/mapsettings.json', falling back to built in map settings
Folder structure:
C:.
│ docker-compose.yml
│ or.txt
├───deployment
│ │ openremote.log.0
│ ├───manager
│ │ │ keycloak.json
│ │ └───app
│ │ │ manager_config.json
│ │ └───images
│ │ img.ico
│ └───map
│ mapdata.mbtiles
│ maptsettings.json
└───info
manager_rm.txt
mapdata_cropped.mbtiles
map_rm.txt
I assume the issue lies in the docker-compose.yml file, specifically the MAP_TILES_PATH and MAP_SETTINGS_PATH environment variables and the manager volumes.
docker-compose.yml:
version: '2.4'
proxy-data:
manager-data:
postgresql-data:
services:
proxy:
restart: always
depends_on:
manager:
condition: service_healthy
ports:
- "80:80"
- "${OR_SSL_PORT:-443}:443"
- "8883:8883"
- proxy-data:/deployment
LE_EMAIL: ${OR_EMAIL_ADMIN:-}
# HAPROXY_CONFIG: '/data/proxy/haproxy.cfg'
postgresql:
restart: always
- manager-data:/storage
keycloak:
restart: always
depends_on:
postgresql:
- ./deployment:/deployment
manager:
# privileged: true
restart: always
depends_on:
keycloak:
OR_SETUP_TYPE:
OR_ADMIN_PASSWORD:
OR_SETUP_RUN_ON_RESTART:
OR_EMAIL_HOST:
OR_EMAIL_USER:
OR_EMAIL_PASSWORD:
OR_EMAIL_X_HEADERS:
OR_EMAIL_FROM:
OR_EMAIL_ADMIN:
OR_FORECAST_SOLAR_API_KEY:
OR_OPEN_WEATHER_API_APP_ID:
MAP_TILES_PATH: ../deployment/map/mapdata.mbtiles # unsure about the path, doesn't seem to matter what I put in here
MAP_SETTINGS_PATH: ../deployment/map/mapsettings.json # same
- ./deployment:/deployment # If I don't comment this line out, then I just encounter a fully white page (also no menu) after the login prompt
Also, could someone explain conceptually what “- ./deployment:/deployment” is supposed to do? Is this a volume and I have to define it somewhere before using it? How come keycloack is using the same “storage thingy”?
Help is greatly appreciated ![]()
Kind regards,
L
