Custom-Project, what to expect under which URL?
I am new to OR und would like to start with my first custom-project. What i managed so far:
  • walked through the various tutorials
  • use IntelliJ CE and start “Custom Deployment”
  • login in to manager UI under localhost:8080 with credentials “admin, secret”
  • see the manager UI and also see the option to change to “Custom” (top right)
According to the code in custom-project i furthermore expected an additional app to be ready under http://localhost:8080/custom with some custom/demo content. Unfortunately this leads to a 404.
Is my assumption right? What can i expect under which URL?
Many thanks for any helpfult and MANY thanks for this great project you created here!!
Best, Thomas
Hey @teichsta ,
To run that app, you need to run the serve NPM script from ui/app/custom/package.json. The console will tell you where you need to go from there.
Hope that helps!
Thanks for your quick response @panos !
Unfortunately not quite. After starting the project from custom-project/ui/app/custom and calling http://localhost:9000/ the Browser console shows:
custom:49  GET http://localhost:9000/modules/@webcomponents/webcomponentsjs/custom-elements-es5-adapter.js net::ERR_ABORTED 404 (Not Found)
custom:1 Refused to execute script from 'http://localhost:9000/modules/@webcomponents/webcomponentsjs/custom-elements-es5-adapter.js' because its MIME type ('text/html') is not executable, and strict MIME type checking is enabled.
custom:86  GET http://localhost:9000/modules/@webcomponents/webcomponentsjs/webcomponents-loader.js net::ERR_ABORTED 404 (Not Found)
custom:1 Refused to execute script from 'http://localhost:9000/modules/@webcomponents/webcomponentsjs/webcomponents-loader.js' because its MIME type ('text/html') is not executable, and strict MIME type checking is enabled.
IntelliJ gives:
Hi @teichsta!
Did you also try to open the “custom” App via http://localhost:9000/custom/ after running npm run serve ?
To also run the custom app in IntelliJ IDEA the OR_CUSTOM_APP_DOCROOT in the “Custom Deployment” run configuration needs to be updated. I created a PR for this:
