Hi all, I can’t export data and i don’t know the problem , any help plz
Can you share some details of your deployment setup?
As in, did you use a docker-compose file? (and what does it look like)
Is this a local setup, or one running on a remote machine in production?
Are you using a custom project, or a fork of OpenRemote?
What version are you running?
hi Martin , i use 1.3 version and i clone OpenRemote github project .For now , it’s a local setup.
The logs page doesn’t include all logs of the OpenRemote Manager.
Do the Docker container logs tell you anything on what exception is thrown?
Oh, and if you’d create a dashboard with the same data, is the data visible?
