Every time I restart my openremote service, the data in it disappears, just like opening it for the first time. So, does openremote need to use persistent storage or a database? I didn’t see it in the documentation.
It clearly uses a database, as shown on this page: Home · openremote/openremote Wiki · GitHub. If your data is cleared, you are probably using a developer option to clear the database at every restart.
As @michal mentioned, you’re probably running on “developer mode”.
These environment variables are useful to adjust / add;
OR_SETUP_RUN_ON_RESTARTenables/disables the clearing and fresh setup of the database. -
OR_DEV_MODEwill enable/disable additional logging and debugging features, and adjusts environment variables useful for development purposes (such as clear database on restart)
Nice to know as well;
Most environment variables are written down in the deploy.yml file in the OpenRemote repo. ![]()
