---- Openremote Setup on a Linux Server ----
It was tested on Ubuntu 12.04 LTS, Ubuntu 13.10, Ubuntu 14.04 LTS, Ubuntu 16.04 LTS and Debian 7 Wheezy
sudo apt-get install subversion openjdk-6-jdk ant tomcat7 mysql-server
sudo service tomcat7 stop
This document assume that you’re starting in your user home directory (/home/ in this case). You MUST replace with your actual username.
Create the Download directory :
mkdir openremote_sources
cd /home//openremote_sources/
DOWNLOAD SOURCES
gwt-2.4.0 :
unzip gwt-2.4.0.zip
Beehive :
wget https://github.com/openremote/Beehive/archive/Beehive_OpenRemote_2_5_1_20160606.zip
unzip Beehive_OpenRemote_2_5_1_20160606.zip
Designer macfly:
svn co http: //svn.code.sf.net/p/openremote/code/tags/snapshot/Designer_2_14_0_SNAPSHOT-2014-01-31_MacFly
Designer 2.5 :
wget https://github.com/openremote/Designer/archive/Designer_2_5_4_20161123.zip
unzip Designer_2_5_4_20161123.zip
Create Logs directories and set permissions :
sudo mkdir -p /var/log/openremote/beehive
sudo mkdir -p /var/log/openremote/designer
sudo chown -R tomcat7:tomcat7 /var/log/openremote
— BEEHIVE 2.5 —
cd /home//openremote_sources/Beehive-Beehive_OpenRemote_2_5_1_20160606/
PREPARE DATABASE
Create DB :
mysql -u root -p
CREATE DATABASE beehive DEFAULT CHARACTER SET utf8;
exit
Import sql template into the db :
mysql -u root -p beehive < ./sql/import.sql
MODIFIED CONFIG FILES
Here is the lines froms configs file you must modify with your text editor (nano in this case):
nano ./build.properties
tomcatconfig.dir=/var/lib/tomcat7/conf
tomcatlog.dir=/var/lib/tomcat7/logs
tomcat.home=/var/lib/tomcat7
deploy.dir=/var/lib/tomcat7/webapps
nano ./config/config.properties
jdbc.url=jdbc:mysql://localhost:3306/beehive?autoReconnect=true&useUnicode=true&characterEncoding=UTF-8
jdbc.username = root
jdbc.password = yourDBpassword
work.dir = /var/lib/tomcat7/webapps/beehive
icons.dir = http://yourIPserver:8080/beehive/icons/
nano ./config/log4j.properties
log4j.appender.errors.File = /var/log/openremote/beehive/errors.log
log4j.appender.errorshtml.File = /var/log/openremote/beehive/errors.html
log4j.appender.beehive.File = /var/log/openremote/beehive/beehive.log
log4j.appender.beehivehtml.File = /var/log/openremote/beehive/beehive.html
log4j.appender.hibernate.File = /var/log/openremote/beehive/hibernate.log
log4j.appender.hibernatehtml.File = /var/log/openremote/beehive/hibernate.html
log4j.appender.spring.File = /var/log/openremote/beehive/spring.log
log4j.appender.springhtml.File = /var/log/openremote/beehive/spring.html
— COMPILLING —
ant war
Copying the output .war file to Tomcat directory :
sudo cp ./output/beehive.war /var/lib/tomcat7/webapps/
sudo service tomcat7 start
You can test now with your web browser : http://yourIPserver:8080/beehive
— DESIGNER macfly—
cd /home//openremote_sources/Designer_2_14_0_SNAPSHOT-2014-01-31_MacFly/
gwt.sdk = /home//openremote_sources/gwt-2.4.0
version = 2.14.0 build.date = 2014-01-16
version.name = macfly
deploy.dir = /designer
beehive.REST.Root.Url = http://yourIPserver:8080/beehive/rest/
webapp.server.root = http://yourIPserver:8080/designer
log4j.appender.user-log.File = /var/log/openremote/designer/users.log
log4j.appender.cache-log.File = /var/log/openremote/designer/cache.log
log4j.appender.cache-debug-log.File = /var/log/openremote/designer/cache-debug.log
log4j.appender.state-log.File = /var/log/openremote/designer/state.log
log4j.appender.state-debug-log.File = /var/log/openremote/designer/state-debug.log
log4j.appender.save-log.File = /var/log/openremote/designer/save.log
log4j.appender.save-debug-log.File = /var/log/openremote/designer/save-debug.log
log4j.appender.restore-log.File = /var/log/openremote/designer/restore.log
log4j.appender.restore-debug-log.File = /var/log/openremote/designer/restore-debug.log
log4j.appender.mail-log.File = /var/log/openremote/designer/mail.log
log4j.appender.resourceservice-log.File = /var/log/openremote/designer/resourceservice.log
log4j.appender.resourceservice-debug-log.File = /var/log/openremote/designer/resourceservice-debug.log
log4j.appender.beehive-log.File = /var/log/openremote/designer/beehive.log
log4j.appender.beehive-debug-log.File = /var/log/openremote/designer/beehive-debug.log
log4j.appender.errors.File = /var/log/openremote/designer/errors.log
log4j.appender.designer.File = /var/log/openremote/designer/designer.log
log4j.appender.hibernate.File = /var/log/openremote/designer/hibernate.log
log4j.appender.spring.File = /var/log/openremote/designer/spring.log
TOMCAT CONFIG
You must modifying Tomcat7 config to prevent JasperException (backward compatibility with Tomcat6), append this at the end of the file :
nano /etc/tomcat7/catalina.properties
org.apache.jasper.compiler.Parser.STRICT_WHITESPACE= false
sudo service tomcat7 restart
COMPILLING
ant war
Copy & rename :
sudo cp ./output/Designer-2.14.0-2014-01-16-macfly.war /var/lib/tomcat7/webapps/designer.war
You can test now with your web browser : http://yourIPserver:8080/designer
Validate A NEW ACCOUNT
If you set the mail server : Create an account and just check your mailbox to click on the link to validate the user.
If not, it will say that the username is not available, but in fact, it was created but not validated. To validate it, modify into beehive database, table user and set “valid” to 1 onto your user line.
UPDATE
userSETvalid= 1 WHEREusername= ‘yourUsername’;
exit
WARNING -----
Designer-macfly serves us only to create accounts, you should not especially use him to design dashboards.
Thus with designer 2.5 I did not find the solution to create accounts we shall use designer-macfly for it!!
Once the accounts created with designer-macfly and validated, it is necessary to move :
**Var/lib/tomcat7/webapps/designer.war and/Var/lib/tomcat7/webapps/designer in a new file “designer_old” **
May proceed to the installation of designer 2.5 ------ WARNING
— Designer 2.5 —
cd /home//openremote_sources/Designer-Designer_2_5_4_20161123/
deviceDiscoveryService.REST.Root.Url = http://yourIPserver:8080/dds/rest/
COMPILLING
ant war
Copy & rename :
sudo cp ./output/Designer-2.5.4-2016-11-23-Designer.war /var/lib/tomcat7/webapps/designer.war
download controller follow this link: https://github.com/openremote/Controller/archive/v2.6.0_beta3.zip
