Is there any way to determine the time when my device was last powered off?
any help will be appreciated.
hi,
what are you trying to achieve? because under the attribute, there is the last update.
actually, client requirement is how much time device is power on .
You mean the Uptime?
In my case I use MQTT Last Will to know when it goes offline, then in case I have a script on my device that logs the time every minute it’s on (so I know if it just lost connection but didn’t turn off)
yes need uptime value.
Your Device got millis? then you could convert millis to hh:mm:ss and publish it.
i will try to do it and i will update here.
but watch out, unsigned long is only 32bit, so the max millis is about 50 days.
Hi @Denis
i got the time in seconds , refer beloe sc
and now i am thinking how i can convert into hours min and second
without proof, but something like this… your attribute has to be a text ofc.
unsigned long startTime;
void setup() {
startTime = millis();
void loop() {
unsigned long currentMillis = millis();
unsigned long uptimeMillis = currentMillis - startTime;
unsigned long seconds = uptimeMillis / 1000;
unsigned long minutes = seconds / 60;
unsigned long hours = minutes / 60;
seconds = seconds % 60;
minutes = minutes % 60;
hours = hours % 24;
String uptimeString = String(hours) + ":" + String(minutes) + ":" + String(seconds);
client.publish(topic, uptimeString);
hi.
i got the time in seconds so
unsigned long seconds = uptimeMillis / 1000; should remove.
Glad to hear that.
