Hi, we are trying to install openremote platform using guide in web
# OpenRemote v3
[](https://github.com/Naereen/badges/)
[Source](https://github.com/openremote/openremote) **·** [Documentation](https://github.com/openremote/openremote/wiki) **·** [Forum](https://forum.openremote.io) **·** [Issues](https://github.com/openremote/openremote/issues) **·** [Docker Images](https://hub.docker.com/u/openremote/) **·** [OpenRemote Inc.](https://openremote.io)
Welcome to the OpenRemote 3.0 platform; an intuitive user-friendly 100% open source IoT platform. We have our origins in Home Automation
but our 3.0 platform is focused on generic IoT applications and is a completely different stack to any of our 2.x services. As the code
base is 100% open source then the applications are limitless. Here's an architecture overview:
## Quickstart
You can quickly try the online demo with restricted access, login credentials are `smartcity:smartcity`:
[Online demo](https://demo.openremote.io/manager/?realm=smartcity)
This file has been truncated. show original
before download docker-compose.yml and run docker-compose up all containers is up normally but i have a message with error Invalid parameter: redirect_uri
and docker status is ok;
what i can do?
Rich
July 30, 2021, 8:20am
2
This is usually caused by not running the stack on localhost; if you are running the stack on a different host or port then you need to supply the EXTERNAL_URL when starting the stack:
# OpenRemote v3
## Quickstart
michal
July 30, 2021, 10:18am
3
The error says Invalid parameter: redirect_uri for which you need to set EXTERNAL_URL . It would help if these both names are consistent IMHO, or even better the error should be something like Environment variable EXTERNAL_URL not set .
nbudel
August 5, 2021, 1:01pm
4
Hi Michal, Im new with Openremote. I’ve the manager running on “localhost” but when i like to make a IP command to the local host, i get the same “redirect_uri” How can you setup/change the EXTENAL URL? Can you help?
michal
August 5, 2021, 1:32pm
5
On Linux or MacOS you do:
export EXTERNAL_URL=https://YOUR_IP_OR_DNS_HERE
Please check the link which @Rich 's given above.
When running the External URL command with CMD the keycloack image gets stuck in a restart loop with the following fatal error:
08:59:51,252 FATAL [org.jboss.as.server] (main) WFLYSRV0239: Aborting with exit code 1
michal
October 27, 2021, 8:37pm
7
ImagineZA:
This seems a different problem. Please create a new thread and give all details of what you are doing and how it is falling.
michal
Closed
January 25, 2022, 8:37pm
8
